Eclipse 3.1 Remote Debug - Start Tomcat 5.5 in debug mode on WinXP? [message #289329] |
Wed, 03 August 2005 18:58 |
Originally posted by: rick.strong.med.nyu.edu
I would like to debug servlets using Eclipse 3.1, servlets are running
on Tomcat 5.5 on a WinXP machine, but I'm having a bit of difficulty
finding the right way to start Tomcat in debug mode and connecting to it
with the Eclipse debugger.
I would be most grateful for any tips, pointers to HOWTOs, or any other
info that specifically targets WinXP and the current version of Tomcat.
Rick Strong
Re: Eclipse 3.1 Remote Debug - Start Tomcat 5.5 in debug mode on WinXP? [message #289333 is a reply to message #289331] |
Wed, 03 August 2005 19:28 |
Thanks for the reply,
When I installed Tomcaton XP, I ended up with no .BAT files. New
feature? I expect there is another way to pass debug configuration info
to the service, but I've been unsuccessful so far.
Rick
FreeGroup wrote:
> Hi
> start tomcat from a command shell with
> "catalina.bat jpda start"
> Configure Eclipse "Run->Debug..."
> create new "Remote Java Application" Entry and configure the port to 8000
> press the 'Debug' button....
> ..thats all (I hope!!)
> greetings
> Andreas
Re: Eclipse 3.1 Remote Debug - Start Tomcat 5.5 in debug mode on WinXP? [message #289737 is a reply to message #289468] |
Wed, 10 August 2005 14:40 |
Andreas,
Thanks very much, I've got it working now. So much better than 2500
println() statements :-)
Rick
FreeGroup wrote:
> don't use the tomcat installation .exe
> You can find a tomcat_xyz.zip on the jakarta webSite.
> unzip the package in any directory. In the bin directory is
> the required catalinat.bat
>> info to the service, but I've been unsuccessful so far.
>> Rick
>> FreeGroup wrote:
>>> Hi
>>> 8000
>>> greetings
>>> Andreas
FUDForum. Page generated in 0.03196 seconds
