How to create a package to run outside of Eclipse [message #289316] |
Wed, 03 August 2005 17:30 |
Originally posted by: m_cayer.hotmail.com
I created a test application in Eclipse Java IDE and ran it. Now, I want to
run it outside of Eclipse. What are the steps that I need to go through to
do this?
-Melissa Cayer
Re: How to create a package to run outside of Eclipse [message #289646 is a reply to message #289316] |
Tue, 09 August 2005 15:01 |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Go to Eclipse's Help, look under
Java Development User Guide->Creating Jar files.
And then just run it as a java application.
Melissa wrote:
> Hello,
> do this?
> -Melissa Cayer
Rich Kulp
Re: How to create a package to run outside of Eclipse [message #289795 is a reply to message #289646] |
Wed, 10 August 2005 19:23 |
Thanks for the info. I created the jar file and clicked on it the file
explorer and got: Could not find main class. Program will exit.
I did select the java class with the Main in it. It runs OK in the IDE. Now,
if I could get it to run outside of the IDE that would be great.
-Melissa
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:ddagff$usn$2@news.eclipse.org...
> Melissa wrote:
>> Hello,
>> to run it outside of Eclipse. What are the steps that I need to go
>> through to do this?
>> -Melissa Cayer
> Rich Kulp
Re: How to create a package to run outside of Eclipse [message #289799 is a reply to message #289795] |
Wed, 10 August 2005 19:52 |
In Jbuilder 2005 IDE, when I run an application, I get the command line in
the messages window at the bottom of the IDE. I can then copy and paste that
command line to the command prompt window of Windows XP and run the process
outside of the IDE.
-Melissa
"Melissa" <m_cayer@hotmail.com> wrote in message
news:dddk7t$fgj$1@news.eclipse.org...
> Hello,
> Now, if I could get it to run outside of the IDE that would be great.
> -Melissa
>> Melissa wrote:
>>> Hello,
>>> through to do this?
>>> -Melissa Cayer
>> Thanks,
>> Rich Kulp
Re: How to create a package to run outside of Eclipse [message #289801 is a reply to message #289799] |
Wed, 10 August 2005 19:56 |
You need a manifest in the jar to indicate the main class to run when
you click on the jar.
When you create the jar file, keep clicking on the "Next" button until
you get to the Manifest page. At the bottom will be where you can browse
for and select the main class for this jar.
Rich Kulp
Re: How to create a package to run outside of Eclipse [message #289804 is a reply to message #289801] |
Wed, 10 August 2005 20:20 |
OK, I did that before and I tried it again, several times. I tried to delete
and start over but I got: Resource is out of sync with the file system:
Search/search.jar when I try to Export, create Jar.
-Melissa
news:dddm5f$hd6$1@news.eclipse.org...
> You need a manifest in the jar to indicate the main class to run when you
> click on the jar.
> When you create the jar file, keep clicking on the "Next" button until you
> get to the Manifest page. At the bottom will be where you can browse for
> Rich Kulp
Re: How to create a package to run outside of Eclipse [message #289806 is a reply to message #289804] |
Wed, 10 August 2005 20:53 |
The jar should not be within your workspace. When you export it should
be somewhere else on your file system. Resource out of sync means that
some file in your workspace was changed by something else other than
Eclipse. When that happens, just do a File->Refresh on the project.
I don't have my system set up to run a jar from the file explorer, but
if I do the command line:
java -jar t.jar
it will work for me.
> -Melissa
>>click on the jar.
>>Thanks,
>>Rich Kulp
Rich Kulp
Re: How to create a package to run outside of Eclipse [message #289810 is a reply to message #289799] |
Thu, 11 August 2005 03:41 |
news:dddltp$hbp$1@news.eclipse.org...
> that command line to the command prompt window of Windows XP and run the
> process outside of the IDE.
> -Melissa
Right-click on the process in the Debug view. Select properties. You will
see the command line information.
Sunil
Re: How to create a package to run outside of Eclipse [message #289992 is a reply to message #289989] |
Tue, 16 August 2005 16:23 |
news:ddt2s4$mds$1@news.eclipse.org...
> When I do that I get:
> FATAL ERROR in native method: No transports initialized
> "Sunil Kamath" <sunil_kamath@nohotspammail.com> wrote in message
> news:ddehdg$9rl$1@news.eclipse.org...
>>> in the messages window at the bottom of the IDE. I can then copy and
>>> paste that command line to the command prompt window of Windows XP and
>>> run the process outside of the IDE.
>>> -Melissa
>> Sunil
If your application runs successfully from within Eclipse, you should not
get this error message.
Does your application run properly when you launch it or debug it?
Sunil
FUDForum. Page generated in 0.03782 seconds
