export problem [message #288318 is a reply to message #288317] |
Fri, 15 July 2005 12:28 |
Originally posted by: xxo.nospam.org
I have some problems exporting my rcp application.
Everything works fine as long as I don´t export into jar
plugins. But in that case certain classes aren´t put into
the jar file. Seems that these are classes with quite long
names ( >32 characters).
Has anybody else expirienced a similar problem?
Any suggestions?
Thanks, Volker
P.S. I use eclipse3.1
Re: export problem [message #290605 is a reply to message #288318] |
Fri, 26 August 2005 17:52 |
Volker wrote:
> Any suggestions?
> Thanks, Volker
https://bugs.eclipse.org/bugs/show_bug.cgi?id=69620
Re: How to associate files without extension with a customized editor? (like Makefile etc) [message #290606 is a reply to message #288317] |
Fri, 26 August 2005 19:55 |
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
See the PDE UI plugin for an example (look in the CVS repository at the
plugin.xml file). You can specify a class (I don't know which one by
heart) which determines if a resource should be opened with your editor.
Martijn.
Martin Olsson wrote:
> How can I associate an Eclipse editor with a file that has no extension?
> My plugin needs to support editing of Makefile's and I don't know how to
> make sure these Makefile's are opened in my customized editor?
FUDForum. Page generated in 0.02643 seconds
