Home » Newcomers » Newcomers » Deleting a linked resource deletes files as well
Deleting a linked resource deletes files as well [message #27369] Wed, 09 February 2005 08:47 Go to next message
Originally posted by: Don.Scales.WesternGeco.com
I created a project and then within the project I create a
link folder that pointed to a directory containing .java
source files.
Later, I wanted to change the project so I selected to delete
the link folder. Eclipse gave me the message
Are you sure you want to delete linked resource 'xyz'?
Only the workspace link will be deleted. Link target will
remain unchanged.
I answered Yes
Eclipse deleted the link and ALL the files in the linked
directory.
I don't think this is meant to happen.
Be very careful using this option.
Don
Re: Deleting a linked resource deletes files as well [message #27374 is a reply to message #27369] Wed, 09 February 2005 11:44 Go to previous messageGo to next message
> source files.
> remain unchanged.
> I answered Yes
> directory.
Somehow I feel a similar option needs to be given for normal files in the
navigator tree.
When I delete a resource (e.g. after an import which added directories I
dont want to see like .cvs or .svn) the actual filesystem object is
removed. I think there should be an option saying a) remove from project
b) remove from project and filesystem
- Sandip
Sandip Bhattacharya * Puroga Technologies * sandip@puroga.com
Work: http://www.puroga.com * Home/Blog: http://www.sandipb.net/blog
PGP/GPG Signature: 51A4 6C57 4BC6 8C82 6A65 AE78 B1A1 2280 A129 0FF3
Re: Deleting a linked resource deletes files as well [message #27633 is a reply to message #27369] Wed, 16 February 2005 10:54 Go to previous message
Originally posted by: john.eclipsefaq.org
I tried this out and wasn't able to reproduce the problem. It certainly
should not be deleting the contents of the linked folder on disk. Are
you able to reproduce this? What version of Eclipse are you using, and
what operating system?
> source files.
> remain unchanged.
> I answered Yes
> directory.
> Regards
> Don
Previous Topic:ActiveX
Next Topic:Time Out while trying to install PlugIns
Current Time: Sat Jul 19 05:09:32 EDT 2025
Powered by FUDForum. Page generated in 0.08581 seconds
