How to unregister xText from an running jboss-eap [message #1480899] |
Thu, 20 November 2014 15:34 |
René Gillessen Messages: 1 Registered: January 2014 |
Junior Member |
Hi all,
I would like to know, how to unregister xText from an running jboss eap.
I would like to implement a restart of an interface that contains the xtext parser.
Redeploy isn't an option (these would work properly).
I get this error message after I try to restart:
1) Error injecting constructor, org.eclipse.emf.common.util.WrappedException: java.lang.RuntimeException: Cannot create a resource for 'eclipse .org/emf/2002/Ecore'; a registered resource factory is needed
I think the reason for this is, that xText is designed as singleton. So I have to unregister the old instance, before I can register a new instance, isn't it?
Thanks for your help,
René
FUDForum. Page generated in 0.03372 seconds
