Home » Language IDEs » Java Development Tools (JDT) » Save Failed (due to NPE in BreakpointMarkerUpdater)
Save Failed (due to NPE in BreakpointMarkerUpdater) [message #257634] Thu, 27 November 2008 07:48 Go to next message
I am running Ganymede on Fedora 10 (x86_64) with Open JDK 1.6.
After debugging I cannot edit files, during save it shows me dialog with
NullPointerException message.
In log:
!SESSION 2008-11-27 14:31:43.524
eclipse.buildId=M20080911-1700
java.version=1.6.0_0
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.ui 4 4 2008-11-27 14:32:15.262
!MESSAGE Save Failed
!ENTRY org.eclipse.ui 2 0 2008-11-27 14:32:15.263
!STACK 0
org.eclipse.jdt.internal.debug.ui.BreakpointMarkerUpdater.up dateMarker(BreakpointMarkerUpdater.java:107)
org.eclipse.ui.texteditor.AbstractMarkerAnnotationModel.upda teMarker(AbstractMarkerAnnotationModel.java:511)
org.eclipse.ui.texteditor.AbstractMarkerAnnotationModel.upda teMarkers(AbstractMarkerAnnotationModel.java:571)
org.eclipse.ui.texteditor.AbstractMarkerAnnotationModel.comm it(AbstractMarkerAnnotationModel.java:636)
org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer .commitFileBufferContent(ResourceTextFileBuffer.java:406)
org.eclipse.core.internal.filebuffers.ResourceFileBuffer.com mit(ResourceFileBuffer.java:321)
org.eclipse.jdt.internal.ui.javaeditor.DocumentAdapter.save( DocumentAdapter.java:458)
org.eclipse.jdt.internal.core.CommitWorkingCopyOperation.exe cuteOperation(CommitWorkingCopyOperation.java:123)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:709)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:775)
org.eclipse.jdt.internal.core.CompilationUnit.commitWorkingC opy(CompilationUnit.java:377)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider.commitWorkingCopy(CompilationUnitDocumentProvider .java:1329)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider$4.execute(CompilationUnitDocumentProvider.java:14 00)
org.eclipse.ui.editors.text.TextFileDocumentProvider$Documen tProviderOperation.run(TextFileDocumentProvider.java:130)
org.eclipse.ui.actions.WorkspaceModifyDelegatingOperation.ex ecute(WorkspaceModifyDelegatingOperation.java:69)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:104)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:116)
org.eclipse.ui.internal.editors.text.WorkspaceOperationRunne r.run(WorkspaceOperationRunner.java:73)
org.eclipse.ui.internal.editors.text.WorkspaceOperationRunne r.run(WorkspaceOperationRunner.java:63)
org.eclipse.ui.editors.text.TextFileDocumentProvider.execute Operation(TextFileDocumentProvider.java:454)
org.eclipse.ui.editors.text.TextFileDocumentProvider.saveDoc ument(TextFileDocumentProvider.java:770)
org.eclipse.ui.texteditor.AbstractTextEditor.performSave(Abs tractTextEditor.java:4791)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .performSave(CompilationUnitEditor.java:1228)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .doSave(CompilationUnitEditor.java:1281)
org.eclipse.ui.texteditor.AbstractTextEditor$TextEditorSavab le.doSave(AbstractTextEditor.java:6887)
at org.eclipse.ui.Saveable.doSave(Saveable.java:212)
org.eclipse.ui.internal.SaveableHelper.doSaveModel(SaveableH elper.java:339)
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper. java:185)
at org.eclipse.ui.internal.SaveableHelper$4.run(SaveableHelper. java:266)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:458)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:366)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2487)
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:274)
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:253)
org.eclipse.ui.internal.SaveableHelper.saveModels(SaveableHe lper.java:196)
org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:136)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1350)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:3291)
org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:3304)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:74)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler. java:185)
org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execut e(LegacyHandlerWrapper.java:109)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:472)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:824)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:882)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:571)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:512)
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:127)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:143 6)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1157)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1182)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1167)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1194 )
at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.ja va:698)
at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control. java:2765)
org.eclipse.swt.widgets.Composite.gtk_key_press_event(Compos ite.java:702)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1543)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4506 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4099 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:57 92)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1177)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive
Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1550)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3031)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Re: Save Failed (due to NPE in BreakpointMarkerUpdater) [message #257640 is a reply to message #257634] Thu, 27 November 2008 09:27 Go to previous message
> with NullPointerException message.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=244920.
Note that the newsgroup is the wrong place to report bugs. Please use
bugzilla.
Dani
> In log:
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Include resources into the JAR
Next Topic:Build Automatically not working with version 3.4.1
Current Time: Thu Apr 17 20:00:55 EDT 2025
Powered by FUDForum. Page generated in 0.03371 seconds
