Re: java.lang.NoSuchMethodError:main [message #255190 is a reply to message #255182] |
Thu, 01 May 2008 15:06 |
Jon,
What you describe sounds like a runtime error, not an compile time
error. The standard signature for the main method is
public static void main(String[] args)
so when you run a class, that's what the system will look for.
Note that since Add is a static method, you can do Mathz.add(50, 50);
i.e., you don't need an instance. Also note that standard Java
conventions would direct you to give all methods (except
constructors,which use the class' name) a name that starts with a lower
case letter.
Jon wrote:
> The following program won't compile, although it compiled with a
> native Java compiler. So far the problem only happened once.
> Package - TestTwo
> Mathz.java
> public class Mathz {
> public static double Add (double aNumber1, double aNumber2) {
> return (aNumber1 + aNumber2);
> MathzTest.java
> public class MathzTest {
> public static void main() {
> Mathz myMathz = new Mathz();
> System.out.println(myMathz.Add(50, 50));
> Error:
> java.lang.NoSuchMethodError: main
> Exception in thread "main"
> Has this error occurred to anyone else please?
FUDForum. Page generated in 0.03760 seconds
