Home » Language IDEs » Java Development Tools (JDT) » Javadoc location per package (set)
Javadoc location per package (set) [message #252052] Mon, 17 March 2008 09:02 Go to next message
Is there possibility to attach javadoc for a package or set of
packages, globally in a workspace, so it takes effect for any
library which bundles the given packages/APIs?
Stanimir
Re: Javadoc location per package (set) [message #252054 is a reply to message #252052] Mon, 17 March 2008 12:14 Go to previous messageGo to next message
Stanimir Stamenkov wrote:
> Is there possibility to attach javadoc for a package or set of packages,
> globally in a workspace, so it takes effect for any library which
I'm not sure I understand your question. Are you talking about attaching
Javadoc that you have created for your source code and making that
available to users of your API (for example, within a JAR file)? Or are
you referring to attaching Javadoc to an external JAR file for use in
your Eclipse projects?
It might help if you could give a detailed example of what you would
like to do. For example, "I have two Java projects ProjectA and ProjectB
that need to ...". Then it might be easier for someone to help you.
Thanks. Mark
Re: Javadoc location per package (set) [message #252078 is a reply to message #252054] Tue, 18 March 2008 03:49 Go to previous message
/Mark Dexter/:
>> packages, globally in a workspace, so it takes effect for any library
All of the Java EE APIs may are bundled in different libraries/JARs
for different projects and the different JARs may bundle some or
more of the given set of APIs. I want to attach the complete Java
EE API doc for all JARs which include some of the given set of API
packages. Thus said it may result one JAR has couple of javadoc
locations attached depending on the packages it bundles.
Stanimir
Previous Topic:Unable to set Compiler Complaince Level to 1.5 (or 5.0)
Next Topic:CVS Reorg, Multiple Projects in a Workspace
Current Time: Wed Apr 23 01:53:13 EDT 2025
Powered by FUDForum. Page generated in 0.04712 seconds
