project setup for a client program which use two jar files [message #251696] |
Fri, 29 February 2008 08:58  |
Originally posted by: wong_powah.yahoo.ca
What is the best way to setup a project for a client program C (in
directory1) which use my two own JCA/JCE jar files created from directory2
and directory3?
For my current project setup, when I single step into C, the source files
of the jar files cannot be found even though I had specified directory2
and directory3.
Which documentation or tutorial I should read?
Re: project setup for a client program which use two jar files [message #251724 is a reply to message #251699] |
Fri, 29 February 2008 12:17  |
Source files are at
C:\win10\JavaSP\com\mycomp\crypto\X509
C:\win10\JavaSP\com\mycomp\cryptox
Then compiled and created MyJCASP.jar and MyJCESP.jar at C:\win10\JavaSP.
javac -classpath ibmpkcs.jar -d . com\mycomp\crypto\*.java
com\mycomp\cryptox\*.java com\mycomp\crypto\X509\*.java
jar -cf MyJCASP.jar com\mycomp\crypto\*.class
com\mycomp\crypto\X509\*.class
jar -cf MyJCESP.jar com\mycomp\cryptox\*.class
The two jar files are copied to C:\Program
Files\Java\jdk1.5.0_14\jre\lib\ext.
When a java project is created, the two jar files MyJCASP.jar and
MyJCESP.jar will appear in the "JRE System Library".
Then I select and right click the two jar files MyJCASP.jar and
MyJCESP.jar one by one by attach source by "Properties", "Java Source
Attachment", "External Folder".
Set the values to C:/win/Java_dir/Java/com/mycomp/crypto and
C:/win/Java_dir/Java/com/mycomp/cryptox respectively.
Looking at the "Project", "Properties", "Java Build Path", "Libraries",
"Source Attachment" confirm that the directory are set.
However, I still get the "Source Not Found" error.
FUDForum. Page generated in 0.06568 seconds
