Problems with upgrading and plugins [message #251694] |
Mon, 17 March 2008 12:23 |
Originally posted by: jm.vse-it-media.de
I am a newbie regarding the use of Eclipse.
Was using Windows 2003 and installed Eclipse.
Seemed to work. But I can't do any upgrades:
I get the following messages:
Network connection problems encountered during search.
Unable to access "http://download.eclipse.org/releases/europa".
Error parsing site stream. [Premature end of file.]
Unable to access "http://update.eclipse.org/updates/3.3".
I wanted to try to find and install an UML plugin.
Any recommendations regarding the latter or ideas about my problem?
Thanks for reading this!
Re: Problems with upgrading and plugins [message #251748 is a reply to message #251694] |
Tue, 18 March 2008 07:36 |
Originally posted by: yeronimuz.aol.com
J. Mayer wrote:
> Hello,
Are you sure you're not behind a firewall or proxy?
If so, set your preferences (Window, preferences, general, Network
connections
Lots of UML tools I know are quite expensive. For a free one look at
AmaterasUML.
Jeroen
Re: Problems with upgrading and plugins [message #251755 is a reply to message #251748] |
Tue, 18 March 2008 09:43 |
Thank you,
It is probably indeed a firewall issue.
Told my boss about it and he will talk about it with the enterprise
responsible for our sys-adminstation. Low priority though, which
means I will have to wait a while.
About the UML stuff, so there are no free plugins for Eclipse?
Re: Problems with upgrading and plugins [message #251941 is a reply to message #251755] |
Thu, 20 March 2008 04:20 |
J. Mayer wrote:
> Thank you,
Even if you are behind a web proxy, you can specify the proxy
information to Eclipse so that it can get through it to download
updates. Open the Preferences dialog and type "proxy" into the search
field to find the appropriate preferences section.
Hope this helps,
Eric
FUDForum. Page generated in 0.08957 seconds
