Home » Language IDEs » Java Development Tools (JDT) » Wy no error is reported for this bad cast ?
Wy no error is reported for this bad cast ? [message #251593] Thu, 21 February 2008 07:36 Go to next message
Originally posted by: none.domain.invalid
In the test case below, why the forced cast is OK ?
I'm using 3.4M5. Should i fill a bug or is it a "feature" ?
public class TestCast {
public interface I { }
public class B { }
public class Container {
Object get() { return null; }
public class SubContainer {
I get() { return null; }
void foo() {
Object[] objets = new Object[1];
// Type mistmath: Cannot convert from TestCast.I to TestCast.B
B b1 = ((SubContainer) objets[0]).get();
// forcing the cast is OK
B b2 = (B)((SubContainer) objets[0]).get();
Re: Wy no error is reported for this bad cast ? [message #251598 is a reply to message #251593] Thu, 21 February 2008 07:46 Go to previous messageGo to next message
The value might be an instance of
public class IB extends B implements I
> public class B { }
> void foo() {
Re: Wy no error is reported for this bad cast ? [message #251602 is a reply to message #251598] Thu, 21 February 2008 07:57 Go to previous message
Thanks! I added a final to "B" class, and there was errors :)
Previous Topic:Need a recap on JSR-045 !
Next Topic:Thank you so much for the Javadoc hover with hyperlinks !!!
Current Time: Fri Apr 25 02:57:12 EDT 2025
Powered by FUDForum. Page generated in 0.03063 seconds
