Home » Language IDEs » Java Development Tools (JDT) » I cannot insert statement into the "block" code.
I cannot insert statement into the "block" code. [message #251115] |
Wed, 30 January 2008 03:22  |
Originally posted by: cikinohana.hotmail.com
Hello everyone,
I created a new "block" node and then want to insert an ASTNode of
statement type into the block node, but it seemed the statement node could
not be inserted into the block. The code is as follows:
/**Insert the given node to the given block node;
* @param node:the node to be inserted to the block;
* @param block: the block to have node inserted;
public void insertIntoBlock(ASTNode node, Block block){
ASTRewrite rewriter = ASTRewrite.Create(node.getAST());
ListRewrite statementsListRewrite = rewriter.getListRewrite(block,
Block.STATEMENTS_PROPERTY);
statementsListRewrite.insertFirst(ASTNode.copySubtree(node.g etAST(),
node), null);
TextEdit edits = rewriter.rewriteAST(Documentation.getDoc(), null);
//Documentation.getDoc() returns a Document object which stores current
(modified) source codein this project;
edits.apply(Documentation.getDoc());
I think this code should work, but it doesn't. Can you help me out of this
problem? Thank you very much.
cikinohana
Re: I cannot insert statement into the "block" code. [message #251120 is a reply to message #251115] |
Wed, 30 January 2008 05:33   |
Originally posted by: 4cs6fcg02.sneakemail.com
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enigEEBB2F0818B12331671EB8BF
Content-Type: text/plain; charset=UTF-8; format=flowed
cikinohana schreef:
> Hello everyone,
> I created a new "block" node and then want to insert an ASTNode of=20
> statement type into the block node, but it seemed the statement node=20
> could not be inserted into the block. The code is as follows:
>=20
> * * @param node:the node to be inserted to the block;
>=20
> ASTRewrite rewriter =3D ASTRewrite.Create(node.getAST()); =
=20
> ListRewrite statementsListRewrite =3D rewriter.getListRewrite(block,
> =20
> statementsListRewrite.insertFirst(ASTNode.copySubtree(node.g etAST(),=20
> node), null);
> TextEdit edits =3D rewriter.rewriteAST(Documentation.getDoc(), n=
ull);
> //Documentation.getDoc() returns a Document object which stores=
=20
> current (modified) source codein this project;
> =20
>=20
> I think this code should work, but it doesn't. Can you help me out of=20
> this problem? Thank you very much.
I do not know what Block is, nor what Documentation, ASTNode,=20
ASTRewrite, TextEdit and ListRewrite are. You don=E2=80=99t indicate whe=
re the=20
problem is. How can we help you if you do not give enough information?
Read the link below and ask again.
H.
--=20
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.4-svn0 (GNU/Linux)
Comment: Using GnuPG with SUSE - http://enigmail.mozdev.org
iD8DBQFHoFJ+e+7xMGD3itQRAvoMAJ9sbYeYOw0MwbX0J2fKgonRS/QGVwCf YNbr
7m/8wyAuDC1zbTqTj/FpEyo=
=48At
-----END PGP SIGNATURE-----
--------------enigEEBB2F0818B12331671EB8BF--
Re: I cannot insert statement into the "block" code. [message #251123 is a reply to message #251115] |
Wed, 30 January 2008 11:29   |
Originally posted by: jacek.pospychala.pl.ibm.com
cikinohana,
If you want to modify block, not node, maybe it would be more reasonable
to create rewriter for block.getAST() and then in copySubtree also use
block.getAST() as target.
Also does it work if you insert something simple, eg
"block.getAST().newBlock()", instead of "ASTNode.copySubtree(...)"?
I'm asking, because I've tried your code and it works - so maybe the
problem is somewhere else.
cikinohana wrote:
> Hello everyone,
> node), null);
> null);
> stores current (modified) source codein this project;
> cikinohana
Re: I cannot insert statement into the "block" code. [message #251127 is a reply to message #251120] |
Wed, 30 January 2008 11:58   |
Originally posted by: wharley.bea.com
"Hendrik Maryns" <4cs6fcg02@sneakemail.com> wrote in message
news:fnpjpu$nl9$1@build.eclipse.org...
> ASTRewrite, TextEdit and ListRewrite are. You don't indicate where the
Hi, Hendrik. Maybe you are overreacting a little? :-)
Tthe types that the poster is referring to are commonly used elements of the
public JDT DOM AST (org.eclipse.jdt.core.dom and ....dom.rewrite), as
discussed here:
http://www.eclipse.org/articles/article.php?file=Article-Jav aCodeManipulation_AST/index.html .
These are types that someone familiar with the JDT API should be aware of,
and this post is in eclipse.tools.jdt so it seems reasonable to assume that
level of knowledge. The only exception is the type Documentation, which the
comment in his code explains.
You are right that it would be helpful if he were more articulate about what
he means by "I think this code should work, but it doesn't."
Re: I cannot insert statement into the "block" code. [message #251185 is a reply to message #251127] |
Fri, 01 February 2008 09:45  |
--------------enig6C0730CEE7B0B4D10C1A8706
Walter Harley schreef:
> "Hendrik Maryns" <4cs6fcg02@sneakemail.com> wrote in message=20
>> ASTRewrite, TextEdit and ListRewrite are. You don't indicate where th=
e
>> problem is. How can we help you if you do not give enough information=
>=20
>=20
> Tthe types that the poster is referring to are commonly used elements o=
f the=20
> public JDT DOM AST (org.eclipse.jdt.core.dom and ....dom.rewrite), as=20
> discussed here:=20
> http://www.eclipse.org/articles/article.php?file=3DArticle-J avaCodeMani=
pulation_AST/index.html .=20
> These are types that someone familiar with the JDT API should be aware =
of,=20
> and this post is in eclipse.tools.jdt so it seems reasonable to assume =
that=20
> level of knowledge. The only exception is the type Documentation, whic=
h the=20
Ah, yes, I am reading this newsgroup from the viewpoint of an Eclipse=20
user, not an Eclipse developer. Sorry.
H.
--=20
Hendrik Maryns
http://aouw.org
iD8DBQFHozCUe+7xMGD3itQRAh5pAJ9Z4tVr2PVKsuf4haxLmcLLMXKnlgCc D4q0
m0s0NLKqHu7RVjNo/3jUQ/k=
=XRkm
--------------enig6C0730CEE7B0B4D10C1A8706--
Current Time: Mon Apr 28 12:19:09 EDT 2025
Powered by FUDForum. Page generated in 0.02942 seconds
