Home » Newcomers » Newcomers » How to access property.
How to access property. [message #239615] Fri, 02 November 2007 16:49 Go to next message
hi,
I am new in Eclipse GMF. I want to access the property of a node Task(the
name property of Task) to write in a file. I tried to access in following
way:
String n="";
Task t=null;
n=t.getName();
fileWriter.write(n);
can any one help me in this regard
thanks in advance.
Noor
Re: How to access property. [message #239625 is a reply to message #239615] Fri, 02 November 2007 16:59 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Unless getName() is a static method, this is going to generate a
NullPointerException at run time. You need to assign t to an actual Task
instance.
"Noor" <nhlangrial@yahoo.com> wrote in message
news:54f86b98fcdeed4d200a9418bc469c5a$1@www.eclipse.org...
> hi,
> way:
> String n="";
> Task t=null;
> n=t.getName();
> thanks in advance.
> Noor
Re: How to access property. [message #239644 is a reply to message #239625] Sat, 03 November 2007 09:08 Go to previous message
thanks for the reply. if you can give me a hint how I can assign Task t to
an actual instance? it will be better if you explain it with example.
Thank you very much for your interest
Previous Topic:javadoc for plug-in not working
Next Topic:Installation - Java and C++
Current Time: Tue Jul 22 15:40:32 EDT 2025
Powered by FUDForum. Page generated in 0.10650 seconds
