Home » Modeling » TMF (Xtext) » SystemC to Promela transformer
SystemC to Promela transformer [message #1328303] Fri, 02 May 2014 16:21 Go to next message
Reza Sheykhi is currently offline Reza SheykhiFriend
I want to get a SystemC program as an input and generate its equal Promela code as an output. SystemC is a library in C++ and Promela is a formal language. To do so, I could find several options: Xtext, Antlr, and LLVM. I am not sure which option is the best and easier/faster to get this project done.
If I use Xtext, I need to write everything from scratch, which needs a lot of efforts. also using LLVM as a parser is very complicated since LLVM is a complex parser.
Would you please help me to find the right way to do this. If I want to use Xtext, do I need to use the whole C++ grammar?
Reza
Re: SystemC to Promela transformer [message #1328528 is a reply to message #1328303] Fri, 02 May 2014 18:52 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
Do not write a new C++ parser; it will take a very very long time to get
right.
You certainly need necessarily all of the C++ grammar and a good C++
preprocessor too.
You should re-use an existing C++ parser, (g++ if you refuse to invest
in a good commercial offering).
If you really insist on writing a parser use an LALR grammar and my C++
grammar, which is the only yaccable implementation
(http://www.parashift.com/c++-faq/yaccable-grammar.html). Read chapter 4
of my thesis
http://www.computing.surrey.ac.uk/research/dsrg/fog/FogThesis.pdf
Ed Willink
On 02/05/2014 19:39, Reza Sheykhi wrote:
> Reza
Re: SystemC to Promela transformer [message #1328542 is a reply to message #1328303] Fri, 02 May 2014 19:00 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
did you have a look at mbeddr?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: SystemC to Promela transformer [message #1334802 is a reply to message #1328542] Mon, 05 May 2014 19:15 Go to previous messageGo to next message
Ed,
If I want to use the current C++ parsers what do you suggest as the starting point? Do you suggest any specific parser (other than g++)? The input of my problem is a SystemC program, which is a very complicated C++ program. I want to generate an equivalent Timed-Automata or Promela code.
Reza
Re: SystemC to Promela transformer [message #1334811 is a reply to message #1334802] Mon, 05 May 2014 19:19 Go to previous messageGo to next message
Christian,
I haven't seen this technology before. As I could understand from their website, mbeddr is a technology stack that supports extension of C. Does it also support systemC? If yes, how can I generate the equal target model (either Timed-Automata or Promela) using mbeddr?
Reza
Re: SystemC to Promela transformer [message #1334886 is a reply to message #1334811] Mon, 05 May 2014 20:03 Go to previous message
I think you should ask it in the mbeddr community (I don't know if
they already have an eclipse forum)
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Previous Topic:Builder to maintain index of EMF Resources
Next Topic:DSL-Editor not found in runtime-workbench
Current Time: Sun Jan 19 19:39:49 GMT 2020
Powered by FUDForum. Page generated in 0.01985 seconds
