Re: [CDO] problem while assigning roles [message #1323686 is a reply to message #1323566] |
Wed, 30 April 2014 11:35 |
Kuldeep Yadav Messages: 12 Registered: January 2014 |
Junior Member |
Eike Stepper wrote on Wed, 30 April 2014 06:19Am 30.04.2014 12:07, schrieb Kuldeep Yadav:
> I have made a web ui for adding a user and editing existing user. So when I edit a user to assign new roles, it goes
> fine but that does not work when I use that privilege.
> For example, I have a user. And I edit the user i.e. add new Write role in user's list of roles and then commit the
> user object to CDO. It seem to happen as expected, but when I create a new object and save it to CDO then it throws
> exception [org.eclipse.emf.cdo.common.security.NoPermissionException: No permission to access
> CDOResource@OID36:0v7("genes")].
Does the problem persist after you've restarted the server and the client?
Yes, I have done that too but didn't work. Also I am using version 4.3, so restart problem have already been fixed I think.
> Is there any special way to assign roles to a user like password.
No.
So what do you suggest to assign role?
Cheers
/Eike
http://www.esc-net.de
[Updated on: Wed, 30 April 2014 11:36] Report message to a moderator
FUDForum. Page generated in 0.02815 seconds
