Home » Newcomers » Newcomers » GMF for JDO : missing connection and link
GMF for JDO : missing connection and link [message #222074] |
Wed, 18 July 2007 07:56 |
Originally posted by: myasic.voila.fr
Hi all.
I'm trying to create diagram editor from jdo.xsd but i miss diagram link.
The model seem's to be ok (see detail below) :
- i have my root node : jdoType
- i have all jdo's sub node : packageType, catalogType, schemaType,
extensionType, queryType ...
But, i have the following problems in others models :
- in the graph model, the connection between jdoType and packageType for
example isn't generated (Figure PolylineConnection, connections and
PolylineDecoration)
- in the mapping model, the link mapping isn't generated
Is it normal ?
Is there any problem in the schema (i took 2.1 version to avoid
cos-nonambig) ?
Thanks for all.
In jdo.xsd :
<xs:element name="jdo">
<xs:complexType>
<xs:choice maxOccurs="unbounded">
<xs:element ref="extension"/>
<xs:element ref="package"/>
<xs:element ref="query"/>
</xs:choice>
<xs:attributeGroup ref="attlist.jdo"/>
</xs:complexType>
</xs:element>
In jdo.ecore :
<eClassifiers xsi:type="ecore:EClass" name="JdoType">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="jdo_._type"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="group"
unique="false" upperBound="-1"
eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EFeatureMapEntry">
<eAnnotations
<details key="kind" value="group"/>
<details key="name" value="group:0"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EReference" name="extension"
upperBound="-1"
eType="#//ExtensionType" volatile="true" transient="true"
derived="true" containment="true"
resolveProxies="false">
<eAnnotations
<details key="kind" value="element"/>
<details key="name" value="extension"/>
<details key="namespace" value="##targetNamespace"/>
<details key="group" value="#group:0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="package"
upperBound="-1"
eType="#//PackageType" volatile="true" transient="true"
<eAnnotations
<details key="name" value="package"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="query"
upperBound="-1"
eType="#//QueryType" volatile="true" transient="true"
<eAnnotations
<details key="name" value="query"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="catalog"
http://www.eclipse.org/emf/2003/XMLType#//AnySimpleType">
<eAnnotations
<details key="kind" value="attribute"/>
<details key="name" value="catalog"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="schema"
<eAnnotations
<details key="name" value="schema"/>
</eAnnotations>
</eClassifiers>
Eclipse conf :
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
com.oxygenxml.editor.home.url=file:/D:/eclipseGmf/plugins/co m.oxygenxml.editor_8.2.0/
com.oxygenxml.editor.lib.dir=D:\eclipseGmf\plugins\com.oxyge nxml.editor_8.2.0\lib
com.oxygenxml.is.eclipse.plugin=true
eclipse.buildId=I20070625-1500
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
D:\eclipseGmf\eclipse.exe
-name
Eclipse
--launcher.library
D:\eclipseGmf\plugins\org.eclipse.equinox.launcher.win32.win 32.x86_1.0.0.v20070523\eclipse_1017a.dll
-startup
D:\eclipseGmf\plugins\org.eclipse.equinox.launcher_1.0.0.v20 070606.jar
-exitdata
cc4_6c
-clean
-vm
D:\Java150_12\bin\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1184678431500
eclipse.vm=D:\Java150_12\bin\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
http.nonProxyHosts=127.0.0.1|localhost
http.proxyHost=proxyaws.unedic.fr
http.proxyPassword=*******
http.proxyPort=8080
http.proxySet=true
http.proxyUser=slabbe
http.proxyUserName=slabbe
https.nonProxyHosts=127.0.0.1|localhost
https.proxyHost=proxyaws.unedic.fr
https.proxyPassword=*******
https.proxyPort=8080
https.proxySet=true
https.proxyUser=slabbe
https.proxyUserName=slabbe
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=D:\eclipseGmf\plugins\org.eclipse.equinox.la uncher_1.0.0.v20070606.jar
java.class.version=49.0
java.endorsed.dirs=D:\Java150_12\lib\endorsed
java.ext.dirs=D:\Java150_12\lib\ext
java.home=D:\Java150_12
java.io.tmpdir=D:\DOCUME~1\DME8684\LOCALS~1\Temp\
java.library.path=D:\Java150_12\bin;.;C:\WINDOWS\System32;C: \WINDOWS;D:\ProgCFA\j2sdk1.4.2_02\bin;C:\oraclexe\app\oracle \product\10.2.0\server\bin;D:\ant\bin;C:\WINDOWS\system32;C: \WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\system32\nls;C: \WINDOWS\system32\nls\FRANCAIS;d:\ProgCFA\Rational\clearcase \bin;D:\ProgCFA\IBM\SQLLIB\BIN;D:\ProgCFA\IBM\SQLLIB\FUNCTIO N;D:\ProgCFA\IBM\SQLLIB\SAMPLES\REPL;C:\Program
Files\Novell\ZENworks\;D:\sdk5\bin;Z:.
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_12-b04
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_12
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_12-b04
line.separator=
org.eclipse.update.resolution_url=
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=fr
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=D:\eclipseGmf\configuration\org.eclipse.osg i\bundles
osgi.clean=true
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/D:/eclipseGmf/configuration/
osgi.framework=file:/d:/eclipseGmf/plugins/org.eclipse.osgi_ 3.3.0.v20070530.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.0.v20070530
osgi.install.area=file:/D:/eclipseGmf/
osgi.instance.area=file:/D:/workspaceGmf2/
osgi.instance.area.default=file:/D:/Documents and
Settings/DME8684/workspace/
osgi.logfile=D:\workspaceGmf2\.metadata\.log
osgi.manifest.cache=D:\eclipseGmf\configuration\org.eclipse. osgi\manifests
osgi.nl=fr_FR
osgi.os=win32
osgi.splashPath=platform:/base/plugins/com.yoxos.distributio n
osgi.syspath=d:\eclipseGmf\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=D:\Java150_12\lib\rt.jar;D:\Java150_12\l ib\i18n.jar;D:\Java150_12\lib\sunrsasign.jar;D:\Java150_12\l ib\jsse.jar;D:\Java150_12\lib\jce.jar;D:\Java150_12\lib\char sets.jar;D:\Java150_12\classes
sun.boot.library.path=D:\Java150_12\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.net.client.defaultConnectTimeout=60000
sun.net.client.defaultReadTimeout=30000
sun.os.patch.level=Service Pack 1
user.country=FR
user.dir=D:\eclipseGmf
user.home=D:\Documents and Settings\DME8684
user.language=fr
user.name=DME8684
user.timezone=Europe/Paris
user.variant=
*** Features:
com.oxygenxml.editor (8.2.0) "oXygen XML Editor"
org.eclipse.emf.codegen (2.3.0.v200706262000) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.0.v200706262000) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200706262000) "EMF Ecore Code
Generation UI"
org.eclipse.emf.common (2.3.0.v200706262000) "EMF Common"
org.eclipse.emf.common.ui (2.3.0.v200706262000) "EMF Common UI"
org.eclipse.emf.converter (2.3.0.v200706262000) "EMF Model Convert Support"
org.eclipse.emf.ecore (2.3.0.v200706262000) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.0.v200706262000) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.0.v200706262000) "Sample Ecore Editor"
org.eclipse.emf.edit (2.3.0.v200706262000) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.0.v200706262000) "EMF Edit UI"
org.eclipse.emf.transaction (1.1.0.v200706071723-208Y8s733G3E4C5B96) "EMF
Model Transaction Core"
org.eclipse.emf.validation (1.1.0.v200706071520-318Y9oA55P5M5P8JA5) "EMF
Validation Framework Core"
org.eclipse.emf.workspace (1.1.0.v200706071723-208Y8s733G3E4C5B96) "EMF
Model Transaction Workbench Integration Core"
org.eclipse.gef (3.3.0.v20070620) "Graphical Editing Framework"
org.eclipse.gmf (1.0.100.v20070601-1400-7d-ETeEYjiMWQX3az0fBWRjypkm7)
"Graphical Modeling Framework"
org.eclipse.jdt (3.3.0.v20070606-0010-7o7jCHEFpPoqQYvnXqejeR) "Eclipse
Java Development Tools"
org.eclipse.ocl (1.1.0.v200706071450-32-9oA55P5M8C8KCK) "Object Constraint
Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.pde (3.3.0.v20070607-7N7M-DUUEF6Ez0H46IcCC) "Eclipse Plug-in
Development Environment"
org.eclipse.platform (3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G) "Eclipse
Platform"
org.eclipse.rcp (3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG) "Eclipse RCP"
org.eclipse.xsd (2.3.0.v200706262000) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.ecore.converter (2.3.0.v200706262000) "XML Schema Infoset
Model (XSD) - org.eclipse.xsd.ecore.converter"
*** Plug-in Registry:
com.ibm.icu (3.6.1.v20070417) "International Components for Unicode for
Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
com.oxygenxml.editor (8.2.0) "oXygen XML Editor" [Active]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle"
[Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738) "SourceForge LPG"
[Resolved]
net.sourceforge.lpg.lpgjavaruntime.source (1.1.0.v200706111738)
"SourceForge LPG Source Bundle" [Resolved]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.batik.bridge (1.6.0.v200706111724) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200706111724) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200706111724) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200706111724) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200706111724) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.parser (1.6.0.v200706111724) "Apache Batik Parser"
[Resolved]
org.apache.batik.svggen (1.6.0.v200706111724) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.transcoder (1.6.0.v200706111724) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200706111724) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200706111724) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200706111724) "Apache Batik XML" [Resolved]
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene Analysis"
[Resolved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver"
[Resolved]
org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Active]
org.eclipse.ant.ui (3.2.100.v20070511) "Ant UI" [Active]
org.eclipse.compare (3.3.0.I20070606) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.0.0.I20070606-0010) "JFace Data Binding"
[Resolved]
org.eclipse.core.databinding.beans (1.0.0.I20070606-0010) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.3.0.v20070606-0010) "File Buffers" [Active]
org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File System
for Windows" [Resolved]
org.eclipse.core.jobs (3.3.0.v20070423) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.0.0.I20070531) "Internet Connection Management"
[Active]
org.eclipse.core.resources (3.3.0.v20070604) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Active]
org.eclipse.debug.core (3.3.0.v20070607-1800) "Debug Core" [Active]
org.eclipse.debug.ui (3.3.0.v20070607-1800) "Debug UI" [Active]
org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework
Draw2d" [Active]
org.eclipse.emf.ant (2.3.0.v200706262000) "EMF Ant Tasks" [Starting]
Generator" [Active]
Generation" [Active]
Generation UI" [Active]
org.eclipse.emf.common (2.3.0.v200706262000) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.3.0.v200706262000) "EMF Common UI" [Active]
Support" [Active]
org.eclipse.emf.ecore (2.3.0.v200706262000) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.3.0.v200706262000) "EMF Ecore Change
Model" [Active]
org.eclipse.emf.ecore.change.edit (2.3.0.v200706262000) "EMF Ecore Change
Edit Support" [Starting]
[Active]
[Starting]
org.eclipse.emf.ecore.xmi (2.3.0.v200706262000) "EMF XMI" [Active]
org.eclipse.emf.edit (2.3.0.v200706262000) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.3.0.v200706262000) "EMF Edit UI" [Active]
org.eclipse.emf.exporter (2.3.0.v200706262000) "EMF Model Export Support"
[Starting]
org.eclipse.emf.importer (2.3.0.v200706262000) "EMF Model Import Support"
[Active]
org.eclipse.emf.importer.ecore (2.3.0.v200706262000) "EMF Ecore Importer"
[Starting]
org.eclipse.emf.importer.java (2.3.0.v200706262000) "EMF Annotated Java
Importer" [Starting]
org.eclipse.emf.importer.rose (2.3.0.v200706262000) "EMF Rose Importer"
[Starting]
org.eclipse.emf.transaction (1.1.0.v200706131240) "EMF Model Transaction
Core" [Active]
org.eclipse.emf.transaction.ui (1.0.100.v200706071723) "EMF Model
Transaction UI" [Starting]
org.eclipse.emf.validation (1.1.0.v200706071520) "EMF Validation Framework
Core" [Active]
org.eclipse.emf.validation.ui (1.1.0.v200706071520) "EMF Validation
Framework UI" [Active]
org.eclipse.emf.validation.ui.ide (1.0.100.v200706071520) "EMF Validation
Framework UI IDE" [Starting]
org.eclipse.emf.workspace (1.1.0.v200706131240) "EMF Model Transaction
Workbench Integration Core" [Active]
org.eclipse.emf.workspace.ui (1.0.100.v200706071723) "EMF Model
Transaction Workbench Integration UI" [Starting]
org.eclipse.equinox.app (1.0.0.v20070606) "Equinox Application Container"
[Active]
org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.http.jetty (1.0.0.v20070607) "Jetty Http Service"
[Starting]
org.eclipse.equinox.http.registry (1.0.0.v20070608) "Http Service Registry
Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.0.v20070606) "Http Services Servlet"
[Starting]
org.eclipse.equinox.jsp.jasper (1.0.0.v20070607) "Jasper Jsp Support
Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp
Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.0.v20070606) "Equinox Launcher"
[Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.0.v20070523) "Equinox
Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.preferences (3.2.100.v20070522) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.3.0.v20070522) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.100.v20070620) "Graphical Editing Framework" [Active]
org.eclipse.gmf (1.0.0.v20070601-1400) "Graphical Modeling Framework"
[Starting]
org.eclipse.gmf.bridge (1.1.0.v20070621-0000) "GMF Models Bridging
Plug-in" [Starting]
org.eclipse.gmf.bridge.ui (1.1.0.v20070621-0000) "GMF Tooling UI" [Active]
org.eclipse.gmf.bridge.ui.dashboard (2.0.0.v20070621-0000) "GMF Dashboard"
[Active]
org.eclipse.gmf.codegen (2.0.0.v20070621-0000) "GMF GenModel and Code
Generation" [Starting]
org.eclipse.gmf.codegen.edit (2.0.0.v20070614-1400) "GMF GenModel Edit
Support" [Starting]
org.eclipse.gmf.codegen.ui (1.1.0.v20070621-0000) "GMF Code Generation UI"
[Starting]
org.eclipse.gmf.common (1.1.0.v20070621-0000) "GMF Tooling Commons
Plug-in" [Active]
org.eclipse.gmf.doc.ui (1.1.0.v20070601-1400) "GMF Documentation
Cheatsheets" [Starting]
org.eclipse.gmf.ecore.editor (2.0.0.v20070621-0000) "ECore Sample Diagram
Plugin" [Active]
org.eclipse.gmf.graphdef (2.0.0.v20070621-0000) "GMF Graphical Definition"
[Resolved]
org.eclipse.gmf.graphdef.codegen (2.0.0.v20070621-0000) "Graphical
Definition Code Generator" [Starting]
org.eclipse.gmf.graphdef.codegen.ui (1.0.100.v20070621-0000) "Graphical
Definition Code Generator UI Support" [Resolved]
org.eclipse.gmf.graphdef.edit (2.0.0.v20070601-1400) "GMFGraph Edit
Support" [Active]
org.eclipse.gmf.map (2.0.0.v20070621-0000) "GMF Mapping Model" [Active]
org.eclipse.gmf.map.edit (2.0.0.v20070621-0000) "GMF Mapping Edit Support"
[Active]
org.eclipse.gmf.runtime.common.core (1.0.100.v20070601-1400) "GMF Common
Core" [Active]
org.eclipse.gmf.runtime.common.ui (1.0.100.v20070601-1400) "GMF Common UI"
[Active]
org.eclipse.gmf.runtime.common.ui.action (1.0.100.v20070601-1400) "GMF
Common UI Action" [Active]
org.eclipse.gmf.runtime.common.ui.action.ide (1.0.1.v20070601-1400) "GMF
Common UI Action IDE" [Active]
org.eclipse.gmf.runtime.common.ui.printing (1.0.1.v20070601-1400) "GMF
Printing" [Starting]
org.eclipse.gmf.runtime.common.ui.printing.win32 (1.0.2.v20070601-1400)
"GMF Printing for Win32" [Resolved]
org.eclipse.gmf.runtime.common.ui.services (1.0.100.v20070601-1400) "GMF
Common UI Services" [Active]
org.eclipse.gmf.runtime.common.ui.services.action (1.0.100.v20070601-1400)
"GMF Common UI Action Services" [Active]
org.eclipse.gmf.runtime.common.ui.services.dnd (1.0.1.v20070601-1400) "GMF
Common UI DND Services" [Starting]
org.eclipse.gmf.runtime.common.ui.services.dnd.ide (1.0.1.v20070601-1400)
"GMF Common UI DND IDE Services" [Starting]
org.eclipse.gmf.runtime.common.ui.services.properties
(1.0.1.v20070601-1400) "GMF Common UI Properties Service Framework"
[Active]
org.eclipse.gmf.runtime.diagram.core (1.0.100.v20070601-1400) "GMF Diagram
Core" [Active]
org.eclipse.gmf.runtime.diagram.ui (1.0.100.v20070621-0000) "GMF Diagram
UI" [Active]
org.eclipse.gmf.runtime.diagram.ui.actions (1.0.100.v20070621-0000) "GMF
Diagram Actions" [Active]
org.eclipse.gmf.runtime.diagram.ui.dnd (1.0.1.v20070601-1400) "GMF Diagram
Browse" [Starting]
org.eclipse.gmf.runtime.diagram.ui.geoshapes (1.0.1.v20070601-1400) "GMF
Geometric Shapes" [Starting]
org.eclipse.gmf.runtime.diagram.ui.printing (1.0.100.v20070621-0000) "GMF
Diagram Printing" [Active]
org.eclipse.gmf.runtime.diagram.ui.printing.render (1.0.1.v20070601-1400)
"GMF Diagram UI Printing Render Plug-In" [Active]
org.eclipse.gmf.runtime.diagram.ui.properties (1.0.100.v20070608-1300)
"GMF Diagram UI Properties" [Active]
org.eclipse.gmf.runtime.diagram.ui.providers (1.0.100.v20070621-0000) "GMF
Diagram Providers" [Active]
org.eclipse.gmf.runtime.diagram.ui.providers.ide (1.0.1.v20070601-1400)
"GMF Diagram Providers IDE" [Active]
org.eclipse.gmf.runtime.diagram.ui.render (1.0.100.v20070621-0000) "GMF
Diagram UI Render Plug-In" [Active]
org.eclipse.gmf.runtime.diagram.ui.resources.editor (1.0.3.v20070601-1400)
"GMF Diagram UI Resources Editor Plug-In" [Active]
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide
(1.0.3.v20070601-1400) "GMF IDE Editor" [Starting]
org.eclipse.gmf.runtime.draw2d.ui (1.0.100.v20070621-0000) "GMF Draw2d
Additions" [Active]
org.eclipse.gmf.runtime.draw2d.ui.render (1.0.100.v20070614-1400) "GMF
Draw2d Image Rendering Additions" [Active]
org.eclipse.gmf.runtime.draw2d.ui.render.awt (1.0.100.v20070614-1400) "GMF
Draw2d Image AWT based Rendering Additions" [Starting]
org.eclipse.gmf.runtime.emf.clipboard.core (1.0.100.v20070621-0000) "GMF
EMF Clipboard Support" [Starting]
org.eclipse.gmf.runtime.emf.commands.core (1.0.3.v20070601-1400) "GMF
Commands" [Active]
org.eclipse.gmf.runtime.emf.core (1.0.100.v20070601-1400) "GMF Modeling
Service Layer" [Active]
org.eclipse.gmf.runtime.emf.type.core (1.0.100.v20070601-1400) "GMF EMF
Type Core" [Active]
org.eclipse.gmf.runtime.emf.type.ui (1.0.1.v20070601-1400) "GMF EMF Type
UI" [Starting]
org.eclipse.gmf.runtime.emf.ui (1.0.100.v20070621-0000) "GMF MSL UI"
[Active]
org.eclipse.gmf.runtime.emf.ui.properties (1.0.2.v20070601-1400) "GMF EMF
UI Properties Providers" [Active]
org.eclipse.gmf.runtime.gef.ui (1.0.1.v20070601-1400) "GMF GEF Additions"
[Active]
org.eclipse.gmf.runtime.notation (1.0.100.v20070621-0000) "GMF Notation
Model Support" [Active]
org.eclipse.gmf.runtime.notation.edit (1.0.1.v20070621-0000) "GMF Notation
Edit Support" [Active]
org.eclipse.gmf.runtime.notation.providers (1.0.1.v20070601-1400) "GMF
Notation Metamodel" [Starting]
org.eclipse.gmf.sdk (1.0.0.v20070601-1400) "Graphical Modeling Framework
SDK" [Starting]
org.eclipse.gmf.tooldef (2.0.0.v20070621-0000) "GMF Tooling Model" [Active]
org.eclipse.gmf.tooldef.edit (2.0.0.v20070601-1400) "GMF Tooling Edit
Support" [Active]
org.eclipse.gmf.validate (1.1.0.v20070621-0000) "GMF Validation" [Active]
org.eclipse.gmf.xpand (1.0.0.v20070608-1300) "GMF Xpand Template Engine"
[Starting]
org.eclipse.help (3.3.0.v20070524) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20070510) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.0.v20070606) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.0.v20070530) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.0.v20070607) "Help System Webapp" [Starting]
org.eclipse.jdt (3.3.0.v20070607-1300) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.3.0.v20070607-1200) "Java Annotation
Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.0.v20070529-2100) "Java Compiler
Apt IDE" [Installed]
org.eclipse.jdt.apt.ui (3.3.0.v20070430-1135) "Java Annotation Processing
UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.0.v20070510-2000) "Java Compiler Apt"
[Installed]
org.eclipse.jdt.compiler.tool (1.0.0.v_771) "Java Compiler Tool Support"
[Installed]
org.eclipse.jdt.core (3.3.0.v_771) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.3.0.v20070530a) "JDI Debug Model" [Starting]
org.eclipse.jdt.debug.ui (3.2.100.v20070531-1800) "JDI Debug UI" [Starting]
org.eclipse.jdt.doc.user (3.3.0.v20070608-1300) "Eclipse Java Development
User Guide" [Starting]
org.eclipse.jdt.junit (3.3.0.v20070606-0010) "Java Development Tools JUnit
support" [Starting]
org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.3.0.v20070510) "Java Development Tools
Launching Support" [Active]
org.eclipse.jdt.ui (3.3.0.v20070607-0010) "Java Development Tools UI"
[Active]
org.eclipse.jface (3.3.0.I20070606-0010) "JFace" [Active]
org.eclipse.jface.databinding (1.1.0.I20070606-0010) "JFace Data Binding
for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.3.0.v20070606-0010) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.0.0.I20070426) "JSch Core" [Starting]
org.eclipse.jsch.ui (1.0.0.I20070525) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.3.0.v20070606-0010) "Refactoring Core"
[Active]
org.eclipse.ltk.ui.refactoring (3.3.0.v20070606-0010) "Refactoring UI"
[Starting]
org.eclipse.ocl (1.1.0.v200706201508) "Object Constraint Language (OCL)
2.0 Parser/Interpreter" [Active]
org.eclipse.ocl.ecore (1.1.0.v200706071450) "OCL 2.0 Binding for Ecore"
[Active]
org.eclipse.osgi (3.3.0.v20070530) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.1.200.v20070605) "OSGi Release 4.0.1
Services" [Resolved]
org.eclipse.osgi.util (3.1.200.v20070605) "OSGi Release 4.0.1 Utility
Classes" [Resolved]
org.eclipse.pde (3.3.0.v20070608-1300) "Eclipse Plug-in Development
Environment" [Active]
org.eclipse.pde.build (3.3.0.v20070612) "Plug-in Development Environment
Build Support" [Active]
org.eclipse.pde.core (3.3.0.v20070608-1300) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.3.0.v20070614-0800) "Eclipse Plug-in
Development User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.3.0.v20070608-1300) "PDE JUnit Plug-in
Test" [Resolved]
org.eclipse.pde.runtime (3.3.0.v20070608-1300) "Plug-in Development
Environment Runtime" [Starting]
org.eclipse.pde.ui (3.3.0.v20070608-1300) "Plug-in Development UI"
[Starting]
org.eclipse.pde.ui.templates (3.3.0.v20070608-1300) "PDE Templates"
[Starting]
org.eclipse.platform (3.3.0.v20070613) "Eclipse Platform" [Starting]
org.eclipse.platform.doc.user (3.3.0.I20070615-1300) "Eclipse Workbench
org.eclipse.rcp (3.2.0.v20070612) "Eclipse RCP" [Starting]
org.eclipse.search (3.3.0.v20070606-0010) "Search Support" [Starting]
org.eclipse.swt (3.3.0.v3346) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.3.0.v3346) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.3.0.I20070607) "Team Support Core" [Active]
org.eclipse.team.ui (3.3.0.I20070607) "Team Support UI" [Active]
org.eclipse.text (3.3.0.v20070606-0010) "Text" [Resolved]
org.eclipse.tomcat (4.1.230.v20070531) "Tomcat Wrapper" [Starting]
org.eclipse.ui (3.3.0.I20070614-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.100.v20070524A) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.3.0.v20070507) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.2.0.v20070530) "Console" [Active]
org.eclipse.ui.editors (3.3.0.v20070606-0010) "Default Text Editor"
[Active]
org.eclipse.ui.externaltools (3.1.200.v20070416) "External Tools" [Active]
org.eclipse.ui.forms (3.3.0.v20070511) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.3.0.I20070620) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.0.I20070530-0100) "Eclipse IDE UI
Application" [Resolved]
org.eclipse.ui.intro (3.2.100.v20070530) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.100.v20070530A) "Universal Welcome"
[Starting]
org.eclipse.ui.navigator (3.3.0.I20070605-0010) "Common Navigator View"
[Active]
org.eclipse.ui.navigator.resources (3.3.0.I20070605-0010) "Navigator
Workbench Components" [Active]
org.eclipse.ui.net (1.0.0.I20070516) "Internet Connection Management UI"
[Active]
org.eclipse.ui.presentations.r21 (3.2.100.I20070605-0010) "R21
Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.2.100.I20070319-0010) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.3.0.I20070605-0010) "Tabbed
Properties View" [Active]
org.eclipse.ui.win32 (3.2.100.I20070319-0010) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.3.0.I20070608-1100) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20070319-0010) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.3.0.v20070606-0010) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.100.v20070615) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.100.v20070615) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.100.v20070615) "Install/Update Core for
Windows" [Resolved]
org.eclipse.update.scheduler (3.2.100.v20070615) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.100.v20070615) "Install/Update UI" [Active]
[Active]
Model (XSD) - org.eclipse.xsd.ecore.converter" [Starting]
org.eclipse.xsd.ecore.exporter (2.3.0.v200706262000) "XML Schema Exporter
for EMF" [Starting]
org.eclipse.xsd.ecore.importer (2.3.0.v200706262000) "XML Schema Importer
for EMF" [Active]
org.junit (3.8.2.v200706111738) "JUnit Testing Framework" [Resolved]
org.junit4 (4.3.1) "JUnit Testing Framework Version 4" [Resolved]
org.mortbay.jetty (5.1.11.v200706111724) "Jetty WebServer" [Resolved]
org.w3c.css.sac (1.3.0.v200706111724) "W3C CSS SAC" [Resolved]
org.w3c.dom.smil (1.0.0.v200706111724) "W3C SMIL DOM" [Resolved]
org.w3c.dom.svg (1.1.0.v200706111724) "W3C SVG DOM" [Resolved]
*** User Preferences:
#Tue Jul 17 17:13:02 CEST 2007
@org.eclipse.debug.ui=3.3.0.v20070607-1800
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
@org.eclipse.ui.ide=3.3.0.I20070620
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1184154239000 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1184154239000"
javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/" name\="Java150_12"
path\="D\:\\Java150_12"/>\r\n</vmType>\r\n</vmSettings >\r\n
@org.eclipse.pde.core=3.3.0.v20070608-1300
/instance/org.eclipse.pde.runtime/activate=true
@org.eclipse.ui.browser=3.2.100.v20070524A
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
@org.eclipse.jdt.ui=3.3.0.v20070607-0010
/project/coffeeshop/org.eclipse.core.resources/encoding//mod el/coffee.ecore_diagram=UTF-8
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.3.0.v20070604
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.pde.core/platform_path=D\:\\eclipseGmf
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/project/JdoEditor/org.eclipse.gmf.bridge.ui.dashboard/gmf_d ashboard/domainGenerationModel=platform\:/resource/JdoEditor /model/jdo_2_1.genmodel
/instance/org.eclipse.ant.ui/useAnnotationsPrefPage=true
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/project/JdoEditor/org.eclipse.gmf.bridge.ui.dashboard/gmf_d ashboard/graphicalDefinitionModel=platform\:/resource/JdoEdi tor/model/jdo.gmfgraph
file_export_version=3.0
@org.eclipse.jdt.launching=3.3.0.v20070510
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
@org.eclipse.pde.runtime=3.3.0.v20070608-1300
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10.0|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.core.net/proxyData/HTTPS/host=proxyaws .unedic.fr
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigra ted=true
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
/instance/org.eclipse.update.core/org.eclipse.update.core.au tomaticallyChooseMirror=true
/instance/org.eclipse.gmf.bridge.ui/show_dashboard=true
/project/JdoEditor/org.eclipse.gmf.bridge.ui.dashboard/gmf_d ashboard/domainModel=platform\:/resource/JdoEditor/model/jdo .ecore
/instance/org.eclipse.ui.ide/platformState=1184678432584
/instance/org.eclipse.core.net/nonProxiedHosts=127.0.0.1|loc alhost
@org.eclipse.core.net=1.0.0.I20070531
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.5
/project/JdoEditor/org.eclipse.gmf.bridge.ui.dashboard/gmf_d ashboard/toolingDefinitionModel=platform\:/resource/JdoEdito r/model/jdo.gmftool
@org.eclipse.gmf.bridge.ui=1.1.0.v20070621-0000
@org.eclipse.gmf.codegen.ui=1.1.0.v20070621-0000
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
/instance/org.eclipse.ui.browser/internalWebBrowserHistory= file\:///D\:/workspaceGmf2/JdoEditor/doc/jdo_2_1.xsd.html\#h 145354019|*|D\:\\workspaceGmf2\\JdoEditor\\doc\\jdo_2_1.xsd. html|*|file\:/D\:/workspaceGmf2/JdoEditor/doc/jdo_2_1.xsd.ht ml|*|
@org.eclipse.ui.editors=3.3.0.v20070606-0010
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=D\:\\wor kspaceGmf2
/instance/org.eclipse.pde.runtime/orderType=2
/instance/org.eclipse.core.net/proxyData/HTTP/host=proxyaws. unedic.fr
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.targetPlatform=1.5
/project/JdoEditor/org.eclipse.gmf.bridge.ui.dashboard/gmf_d ashboard/generationModel=platform\:/resource/JdoEditor/model /jdo.gmfgen
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAU NCH_PERSPECTIVES= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<launchPerspectives/>\r\n
@org.eclipse.emf.converter=2.3.0.v200706262000
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=11
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.inlineJsrBytecode=enabled
@org.eclipse.jdt.core=3.3.0.v_771
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.internal.ui.nav igator.layout=2
@org.eclipse.update.core=3.2.100.v20070615
@org.eclipse.search=3.3.0.v20070606-0010
/instance/org.eclipse.core.net/proxyData/HTTPS/hasAuth=true
/instance/org.eclipse.core.net/proxyData/HTTPS/port=8080
/instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.pde.runtime/orderValue=-1
/instance/org.eclipse.update.ui/ConfigurationView.showUnconf =true
/project/JdoEditor/org.eclipse.gmf.bridge.ui.dashboard/gmf_d ashboard/mappingModel=platform\:/resource/JdoEditor/model/jd o.gmfmap
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<web-browsers
current\="0">\r\n<system/>\r\n<external location\="C\:\\Program
Files\\Internet Explorer\\iexplore.exe" name\="Internet
Explorer"/>\r\n</web-browsers>
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.user_vie w_bindings= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<viewBindings>\r\n<view
id\="org.eclipse.ui.console.ConsoleView">\r\n<perspective
id\="org.eclipse.ui.resourcePerspective"
userAction\="opened"/>\r\n</view>\r\n</viewBindings>\r\n
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .source=1.5
@org.eclipse.gmf.runtime.emf.core=1.0.100.v20070601-1400
/instance/org.eclipse.pde.runtime/column4=150
/instance/org.eclipse.pde.runtime/column3=288
/instance/org.eclipse.gmf.codegen.ui/ask_ok=always
@org.eclipse.team.ui=3.3.0.I20070607
/instance/org.eclipse.pde.runtime/column2=725
/instance/org.eclipse.search/org.eclipse.search.defaultPersp ective=org.eclipse.search.defaultPerspective.none
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.core.net/proxiesEnabled=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/instance/org.eclipse.core.net/proxyData/HTTP/hasAuth=true
/instance/org.eclipse.emf.converter/org.eclipse.emf.importer .ui.contribution.ModelImporterManager=org.eclipse.xsd.ecore. importer
@org.eclipse.ant.ui=3.2.100.v20070511
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.cancel_l aunch_with_compile_errors=always
@org.eclipse.update.ui=3.2.100.v20070615
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.assertIdentifier=error
/instance/org.eclipse.gmf.runtime.emf.core/referenced.path.v ariables=
/instance/org.eclipse.core.net/proxyData/HTTP/port=8080
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
/instance/org.eclipse.jdt.ui/spelling_locale_initialized=tru e
/project/JdoEditor/org.eclipse.core.resources/encoding//mode l/jdo.ecore_diagram=UTF-8
@org.eclipse.ui=3.3.0.I20070614-0800
/instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=always
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=true
*** Current Install Configuration:
Install configuration:
Last changed on 17 juil. 07
file:/D:/eclipseGmf/configuration/org.eclipse.update/platfor m.xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.emf.codegen, Version: null
ID: org.eclipse.xsd.ecore.converter, Version: null
ID: org.eclipse.emf.edit.ui, Version: null
ID: org.eclipse.emf.codegen.ecore, Version: null
ID: org.eclipse.gmf.runtime.thirdparty, Version: null
ID: org.eclipse.emf.ecore.edit, Version: null
ID: org.eclipse.gmf, Version: null
ID: org.eclipse.emf.ecore.editor, Version: null
ID: org.eclipse.emf.common, Version: null
ID: org.eclipse.emf.edit, Version: null
ID: org.eclipse.gmf.europa, Version: null
ID: org.eclipse.emf.transaction, Version: null
ID: org.eclipse.emf.ecore, Version: null
ID: org.eclipse.platform, Version: null
ID: org.eclipse.emf.common.ui, Version: null
ID: org.eclipse.jdt, Version: null
ID: org.eclipse.gef, Version: null
ID: org.eclipse.emf.validation, Version: null
ID: org.eclipse.rcp, Version: null
ID: com.oxygenxml.editor, Version: null
ID: org.eclipse.emf.converter, Version: null
ID: org.eclipse.emf.codegen.ecore.ui, Version: null
ID: org.eclipse.ocl, Version: null
ID: org.eclipse.pde, Version: null
ID: org.eclipse.xsd, Version: null
ID: org.eclipse.emf.workspace, Version: null
Configured plug-ins:
file:/D:/eclipseGmf/plugins/com.ibm.icu_3.6.1.v20070417.jar
file:/D:/eclipseGmf/plugins/com.jcraft.jsch_0.1.31.jar
file:/D:/eclipseGmf/plugins/com.oxygenxml.editor_8.2.0/
file:/D:/eclipseGmf/plugins/javax.servlet.jsp_2.0.0.v2007061 91603.jar
file:/D:/eclipseGmf/plugins/javax.servlet_2.4.0.v20070611173 8.jar
file:/D:/eclipseGmf/plugins/net.sourceforge.lpg.lpgjavarunti me.source_1.1.0.v200706111738.jar
file:/D:/eclipseGmf/plugins/net.sourceforge.lpg.lpgjavarunti me_1.1.0.v200706111738.jar
file:/D:/eclipseGmf/plugins/org.apache.ant_1.7.0.v2007060808 42/
file:/D:/eclipseGmf/plugins/org.apache.batik.bridge_1.6.0.v2 00706111724.jar
file:/D:/eclipseGmf/plugins/org.apache.batik.css_1.6.0.v2007 06111724.jar
file:/D:/eclipseGmf/plugins/org.apache.batik.dom.svg_1.6.0.v 200706111724.jar
file:/D:/eclipseGmf/plugins/org.apache.batik.dom_1.6.0.v2007 06111724.jar
file:/D:/eclipseGmf/plugins/org.apache.batik.ext.awt_1.6.0.v 200706111724.jar
file:/D:/eclipseGmf/plugins/org.apache.batik.parser_1.6.0.v2 00706111724.jar
file:/D:/eclipseGmf/plugins/org.apache.batik.svggen_1.6.0.v2 00706111724.jar
file:/D:/eclipseGmf/plugins/org.apache.batik.transcoder_1.6. 0.v200706111724.jar
file:/D:/eclipseGmf/plugins/org.apache.batik.util.gui_1.6.0. v200706111724.jar
file:/D:/eclipseGmf/plugins/org.apache.batik.util_1.6.0.v200 706111724.jar
file:/D:/eclipseGmf/plugins/org.apache.batik.xml_1.6.0.v2007 06111724.jar
file:/D:/eclipseGmf/plugins/org.apache.commons.el_1.0.0.v200 706111724.jar
file:/D:/eclipseGmf/plugins/org.apache.commons.logging_1.0.4 .v200706111724.jar
file:/D:/eclipseGmf/plugins/org.apache.jasper_5.5.17.v200706 111724.jar
file:/D:/eclipseGmf/plugins/org.apache.lucene.analysis_1.9.1 .v200706181610.jar
file:/D:/eclipseGmf/plugins/org.apache.lucene_1.9.1.v2007061 11724.jar
file:/D:/eclipseGmf/plugins/org.apache.xerces_2.8.0.v2007053 01630.jar
file:/D:/eclipseGmf/plugins/org.apache.xml.resolver_1.1.0.v2 00705310020.jar
file:/D:/eclipseGmf/plugins/org.eclipse.ant.core_3.1.200.v20 070522.jar
file:/D:/eclipseGmf/plugins/org.eclipse.ant.ui_3.2.100.v2007 0511.jar
file:/D:/eclipseGmf/plugins/org.eclipse.compare_3.3.0.I20070 606.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.boot_3.1.100.v2 0060603.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.commands_3.3.0. I20070605-0010.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.contenttype_3.2 .100.v20070319.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.databinding.bea ns_1.0.0.I20070606-0010.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.databinding_1.0 .0.I20070606-0010.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.expressions_3.3 .0.v20070606-0010.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.filebuffers_3.3 .0.v20070606-0010.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.filesystem.win3 2.x86_1.1.0.v20070510.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.filesystem_1.1. 0.v20070606.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.jobs_3.3.0.v200 70423.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.net_1.0.0.I2007 0531.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.resources.compa tibility_3.2.100.v20070502.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.resources.win32 _3.3.0.v20070226.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.resources_3.3.0 .v20070604.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.runtime.compati bility.auth_3.2.100.v20070502.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.runtime.compati bility.registry_3.2.100.v20070316/
file:/D:/eclipseGmf/plugins/org.eclipse.core.runtime.compati bility_3.1.200.v20070502.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.runtime_3.3.100 .v20070530.jar
file:/D:/eclipseGmf/plugins/org.eclipse.core.variables_3.2.0 .v20070426.jar
file:/D:/eclipseGmf/plugins/org.eclipse.debug.core_3.3.0.v20 070607-1800.jar
file:/D:/eclipseGmf/plugins/org.eclipse.debug.ui_3.3.0.v2007 0607-1800.jar
file:/D:/eclipseGmf/plugins/org.eclipse.draw2d_3.2.100.v2007 0529.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.ant_2.3.0.v20070 6262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.codegen.ecore.ui _2.3.0.v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.codegen.ecore_2. 3.0.v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.codegen_2.3.0.v2 00706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.common.ui_2.3.0. v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.common_2.3.0.v20 0706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.converter_2.3.0. v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.ecore.change.edi t_2.3.0.v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.ecore.change_2.3 .0.v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.ecore.editor_2.3 .0.v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.ecore.edit_2.3.0 .v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.ecore.xmi_2.3.0. v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.ecore_2.3.0.v200 706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.edit.ui_2.3.0.v2 00706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.edit_2.3.0.v2007 06262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.exporter_2.3.0.v 200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.importer.ecore_2 .3.0.v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.importer.java_2. 3.0.v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.importer.rose_2. 3.0.v200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.importer_2.3.0.v 200706262000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.transaction.ui_1 .0.100.v200706071723.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.transaction_1.1. 0.v200706131240.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.validation.ui.id e_1.0.100.v200706071520.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.validation.ui_1. 1.0.v200706071520.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.validation_1.1.0 .v200706071520.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.workspace.ui_1.0 .100.v200706071723.jar
file:/D:/eclipseGmf/plugins/org.eclipse.emf.workspace_1.1.0. v200706131240.jar
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.app_1.0.0.v2 0070606.jar
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.common_3.3.0 .v20070426.jar
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.http.jetty_1 .0.0.v20070607.jar
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.http.registr y_1.0.0.v20070608.jar
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.http.servlet _1.0.0.v20070606.jar
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.jsp.jasper.r egistry_1.0.0.v20070607.jar
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.jsp.jasper_1 .0.0.v20070607.jar
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.launcher.win 32.win32.x86_1.0.0.v20070523/
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.launcher_1.0 .0.v20070606.jar
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.preferences_ 3.2.100.v20070522.jar
file:/D:/eclipseGmf/plugins/org.eclipse.equinox.registry_3.3 .0.v20070522.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gef_3.2.100.v2007062 0.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.bridge.ui.dashbo ard_2.0.0.v20070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.bridge.ui_1.1.0. v20070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.bridge_1.1.0.v20 070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.codegen.edit_2.0 .0.v20070614-1400.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.codegen.ui_1.1.0 .v20070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.codegen_2.0.0.v2 0070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.common_1.1.0.v20 070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.doc.ui_1.1.0.v20 070601-1400.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.ecore.editor_2.0 .0.v20070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.graphdef.codegen .ui_1.0.100.v20070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.graphdef.codegen _2.0.0.v20070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.graphdef.edit_2. 0.0.v20070601-1400.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.graphdef_2.0.0.v 20070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.map.edit_2.0.0.v 20070621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.map_2.0.0.v20070 621-0000.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.runtime.common.c ore_1.0.100.v20070601-1400.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.runtime.common.u i.action.ide_1.0.1.v20070601-1400.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.runtime.common.u i.action_1.0.100.v20070601-1400.jar
file:/D:/eclipseGmf/plugins/org.eclipse.gmf.runtime.common.u i.printing.win32_1.0.2.v20070601-1400.jar
Re: GMF for JDO : missing connection and link [message #222101 is a reply to message #222074] |
Wed, 18 July 2007 08:38 |
Originally posted by: jakub.jurkiewicz.gmail.com
Try posting on eclipse.modeling.gmf newsgroup. People there should have
more knowledge.
kind regards
Jakub Jurkiewicz
http://eclipser-blog.blogspot.com/
myasic wrote:
> Hi all.
> The model seem's to be ok (see detail below) : - i have my root node :
> jdoType
> PolylineDecoration)
> Is it normal ?
> cos-nonambig) ?
> Thanks for all.
> In jdo.xsd : ----------------
> <xs:complexType>
> </xs:choice>
> </xs:complexType>
> </xs:element>
> In jdo.ecore : ----------------
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> Eclipse conf :
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> -launcher
> -name
> Eclipse
> --launcher.library
> -startup
> -exitdata
> cc4_6c
> -clean
> -vm
> -Xmx256m
> -jar
> eof=eof
> file.separator=\
> http.proxyPort=8080
> http.proxySet=true
> https.proxySet=true
> line.separator=
vax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.r owset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bo rder,javax.swing.colorchooser,javax.swing.event,javax.swing. filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.sw ing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth ,javax.swing.table,javax.swing.text,javax.swing.text.html,ja vax.swing.text.html.parser,javax.swing.text.rtf,javax.swing. tree,javax.swing.undo,javax.transaction,javax.transaction.xa ,javax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml. parsers,javax.xml.transform,javax.xml.transform.dom,javax.xm l.transform.sax,javax.xml.transform.stream,javax.xml.validat ion,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORB A_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage ,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.COR BA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.Namin gContextExtPackage,org.omg.CosNaming.NamingContextPackage,or g.omg.Dynamic,org.omg.DynamicA
ny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAn y.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage, org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableI nterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,or g.omg.PortableServer,org.omg.PortableServer.CurrentPackage,o rg.omg.PortableServer.POAManagerPackage,org.omg.PortableServ er.POAPackage,org.omg.PortableServer.portable,org.omg.Portab leServer.ServantLocatorPackage,org.omg.SendingContext,org.om g.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.do m.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml. sax.helpers
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.clean=true
> osgi.nl=fr_FR
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=FR
> user.language=fr
> user.name=DME8684
> user.variant=
> *** Features:
> Generation"
> Generation UI"
> "EMF Model Transaction Core"
> Constraint Language (OCL) 2.0 Parser/Interpreter"
> Platform"
> Infoset Model (XSD) - org.eclipse.xsd.ecore.converter"
> [Resolved]
> LPG" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> Analysis" [Resolved]
> [Resolved]
> Mechanism" [Active]
> [Resolved]
> Language" [Active]
> System for Windows" [Resolved]
> [Active]
> [Active]
> Draw2d" [Active]
> Generator" [Active]
> Support" [Active]
> Model" [Active]
> Change Edit Support" [Starting]
> Support" [Active]
> [Starting]
> Support" [Starting]
> Support" [Active]
> [Starting]
> Core" [Active]
> Framework Core" [Active]
> Validation Framework UI IDE" [Starting]
> Container" [Active]
> [Active]
> [Starting]
> Registry Extensions" [Resolved]
> Servlet" [Starting]
> Bundle" [Starting]
> [Resolved]
> Mechanism" [Active]
> Support" [Active]
> [Starting]
> Plug-in" [Starting]
> Dashboard" [Active]
> Support" [Starting]
> UI" [Starting]
> Plug-in" [Active]
> Diagram Plugin" [Active]
> Definition" [Resolved]
> Support" [Active]
> Support" [Active]
> Core" [Active]
> UI" [Active]
> (1.0.100.v20070601-1400) "GMF Common UI Action Services" [Active]
> "GMF Common UI DND Services" [Starting]
> (1.0.1.v20070601-1400) "GMF Common UI DND IDE Services" [Starting]
> [Active]
> Diagram Core" [Active]
> UI" [Active]
> Diagram Browse" [Starting]
> "GMF Diagram Printing" [Active]
> (1.0.1.v20070601-1400) "GMF Diagram UI Printing Render Plug-In" [Active]
> "GMF Diagram Providers" [Active]
> (1.0.3.v20070601-1400) "GMF Diagram UI Resources Editor Plug-In" [Active]
> Additions" [Active]
> "GMF Draw2d Image AWT based Rendering Additions" [Starting]
> Commands" [Active]
> Type Core" [Active]
> UI" [Starting]
> [Active]
> EMF UI Properties Providers" [Active]
> Additions" [Active]
> Notation Edit Support" [Active]
> SDK" [Starting]
> Support" [Active]
> [Starting]
> [Starting]
> [Resolved]
> Processing UI" [Starting]
> [Installed]
> [Installed]
> Development User Guide" [Starting]
> JUnit support" [Starting]
> Development Tools JUnit4 runtime support" [Resolved]
> [Active]
> Core" [Active]
> [Starting]
> [Active]
> Classes" [Resolved]
> [Active]
> Test" [Resolved]
> [Starting]
> [Starting]
> [Active]
> [Starting]
> [Active]
> [Active]
> Framework" [Active]
> Scheduler" [Active]
> [Active]
> Infoset Model (XSD) - org.eclipse.xsd.ecore.converter" [Starting]
> Exporter for EMF" [Starting]
> Importer for EMF" [Active]
> id\="1184154239000"
> name\="Java150_12"
> Location: file:/D:/eclipseGmf/configuration/org.eclipse.update/platfor m.xml
> Configured sites:
> platform:/base/
Current Time: Thu Apr 25 10:11:24 GMT 2024
Powered by FUDForum. Page generated in 0.07636 seconds
