Home » Newcomers » Newcomers » About Eclipse on 64bit Fedora 7
About Eclipse on 64bit Fedora 7 [message #222020] Wed, 18 July 2007 01:16 Go to next message
Originally posted by: kelvinpark86.gmail.com
I am getting the following popup message when start eclipse on 64bit
fedora 7. I have 64bit 6u2 SDK w/ JRE installed. I do not know what the
problem is. Do you know what the problem is?
Thank you.
JVM terminated. Exit code=13
/usr/java/jre1.6.0_02/bin/java
-Xms40m
-Xmx256m
-jar
/home/username/downloads/eclipse/plugins/org.eclipse.equinox .launcher_1.0.0.v20070606.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /home/username/downloads/eclipse/eclipse
-name Eclipse
--launcher.library
/home/username/downloads/eclipse/plugins/org.eclipse.equinox .launcher.gtk.linux.x86_1.0.0.v20070606/eclipse_1017a.so
-startup
-exitdata f0014
-vm /usr/java/jre1.6.0_02/bin/java
-vmargs
-Xms40m
-Xmx256m
-jar
Re: About Eclipse on 64bit Fedora 7 [message #222179 is a reply to message #222020] Wed, 18 July 2007 13:25 Go to previous message
Originally posted by: geo.loyola.edu
"Kelvin" <kelvinpark86@gmail.com> wrote in message
news:f7jplm$mmo$1@build.eclipse.org...
>I am getting the following popup message when start eclipse on 64bit fedora
>7. I have 64bit 6u2 SDK w/ JRE installed. I do not know what the problem
I had the same situation occur trying to start Eclipse on XP x64. David
Wegener gave me this clue:
> There isn't a 64bit version of Eclipse release for Windows yet, so you
> most likely downloaded the 32 bit version. I believe that this will run
> under 64bit XP if you use a 32bit jdk instead of the 64bit one you have
> downloaded.
The 32bit jdk did the trick.
Previous Topic:Can't start eclipse
Next Topic:Charging models dynamically in an ATL transformation
Current Time: Tue Apr 16 12:19:50 GMT 2024
Powered by FUDForum. Page generated in 0.32153 seconds
