Update site tips for https [message #221357] |
Fri, 13 July 2007 10:59 |
Originally posted by: peterramesh.yahoo.com
In our project, we are using Eclipse 3.3. we have one feature and 12
plugins, all were in respective folders in the update site. Here is the
site.xml, which is in the root of our update site.
<site>
<description url="https://<host_name>/<update_site>/site.xml">
Project Update Site
</description>
<feature url="features/com.company.product_1.0.0.jar"
id="com.company.product" version="1.0.0">
<category name="Project_Framework"/>
</feature>
<category-def name="Project_Framework" label="Project_Framework"/>
</site>
The update site is configured with SSL protocol (https). When I try to see
(https://<host_name>/<update_site>/site.xml) the update site, it is
perfectly working in browser way.
But, when I tried to install by eclipse update manager, it always fails
with these following error.
Network connection problems encountered during search.
Unable to access "https://<host_name>/<update_site>/site.xml".
org.eclipse.core.runtime.CoreException: Error parsing site stream.
[Premature end of file.]
at org.eclipse.update.core.Utilities.newCoreException(Utilities .java:223)
at org.eclipse.update.core.Utilities.newCoreException(Utilities .java:254)
Error parsing site stream. [Premature end of file.]
I am behind a proxy server, so given proper authentication.
Please note: I able to successfully install the BEA eclipse plugin from
this URL https://eclipse-plugin.projects.dev2dev.bea.com/update/
Is there any special consideration for https URL's than plain http based
update site?
Any help is greatly welcome.
Thanks and Regards,
Ramesh kumar
Re: Update site tips for https [message #221403 is a reply to message #221357] |
Fri, 13 July 2007 13:03 |
Originally posted by: dmsubs.NOSPAM.consertum.com
I think your description site should read:
> <description url="https://<host_name>/<update_site>/">
> Project Update Site
> </description>
i.e. no "site.xml" on the end.
Derek
Ramesh kumar wrote:
> <site>
> Project Update Site
> </description>
> </feature>
> </site>
> see (https://<host_name>/<update_site>/site.xml) the update site, it is
> update site?
> Thanks and Regards,
> Ramesh kumar
FUDForum. Page generated in 0.02792 seconds
