Install Ecipse classic [message #220787] |
Tue, 10 July 2007 21:10 |
Originally posted by: jeff.perkins.glo.state.tx.us
How do I install Ecipse Classic(windows xp sp2). After downloading the
zip file and extracting it, 777 file are within the zip of which more zip
files are attached. I've tried the setup.exe, eclipse.exe etc.... Whatz
up?
Thanks in advance!
Re: Install Ecipse classic [message #220794 is a reply to message #220787] |
Tue, 10 July 2007 21:29 |
Originally posted by: wharley.bea.com
"jeff" <jeff.perkins@glo.state.tx.us> wrote in message
news:3bcd9fe5fbba4365c01c725a9a9e3523$1@www.eclipse.org...
> up?
When you extract the zip file contents to a location on your hard drive,
you're done; that *is* the installation. There is no installer to run. At
that point, running eclipse.exe should launch Eclipse.
If that is not working for you, make sure you read the note for Windows
users on the download page (which basically says "don't use the Windows
built-in unzip utility because it can't deal with long file names); and make
sure that you preserve folder structure, rather than unzipping everything
into one directory.
Re: Install Ecipse classic [message #220929 is a reply to message #220794] |
Wed, 11 July 2007 22:05 |
Thank you Walter for your response. I used WinZip to uncompress the files
but didn't chose "Use folder names". Once I did, the appropriate files
went to their respective directories. Thereafter, the application
executed successfully.
Thanks again!
FUDForum. Page generated in 0.05239 seconds
