Overriding a default content type [message #220746] |
Tue, 10 July 2007 18:51 |
Originally posted by: eclipse.potophobia.net
I'd like to start coding for Rabbit microprocessors with Eclipse, but
I'm having problems with a file type setting. This is a language called
"Dynamic C" which is close enough to C that it should be usable in Eclipse.
However, Rabbit uses ".lib" to identify libraries in source code format,
rather than the normal static libraries we're used to seeing in other C
environments. When I make a custom file type in the CDT to set "*.lib"
to "C Source File", it saves the setting but nothing changes. Eclipse
still thinks they're static libraries, and thus doesn't color code the
file or analyze the code for its functions and definitions. Is it
possible to disable or override the default ".lib" content type so that
I can use my own?
eth'nT
FUDForum. Page generated in 0.03863 seconds
