Home » Newcomers » Newcomers » Eclipse + 64-Bit Linux
Eclipse + 64-Bit Linux [message #220391] |
Sat, 07 July 2007 16:29 |
Originally posted by: thedaywassaved.yahoo.com
Ok, so here's my setup. I got a HP Dv9000z laptop (AMD Turion 64 Tl-60,
2gbram), and Ubuntu 64 running on it. But, everything i do with eclipse
pdt, returns an error. It sucks, cause im a linux fan, but stuck using
windows for my php apps.
No matter how i install, i keep getting errors. First, i downloaded from
the repositories, eclipse starts, but i cannot install the PDT plugin, as
i am missing GEF, WST and EMF. So i install all, and i get a wrong version
error for the WST, saying i have 1.5.2, and i need 2. Yet i download 2.0,
and it returns it is the 2.0 WTP Server plugin, and not 2.0 WST. So i was
confussed with that. I said screw it cant waste my time. I downloaded the
All In One with the PDT. I get an error on boot.
JVM terminated. Exit code=13
/usr/lib/jvm/java-6-sun-1.6.0.00/jre/bin/java
-Xms40m
-Xmx256m
-jar
/home/reistlehr/Desktop/eclipse/plugins/org.eclipse.equinox. launcher_1.0.0.v20070516.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /home/reistlehr/Desktop/eclipse/eclipse
-name Eclipse
--launcher.library
/home/reistlehr/Desktop/eclipse/plugins/org.eclipse.equinox. launcher.gtk.linux.x86_1.0.0.v20070516/eclipse_1017.so
-startup
-exitdata 1ce005e
-vm /usr/lib/jvm/java-6-sun-1.6.0.00/jre/bin/java
-vmargs
-Xms40m
-Xmx256m
-jar
i have java-1.6.0.00-sun installed. So that's not the problem, i even
tried to downgrade to 1.5 but same exact thing again.
Now, i ended up downlaod eclipse through the repositoreis after getting
rid of eveything, and it loaded. i downloaded the sdk for the pdt, and put
it in, and it works, but i cannot create a project. everytime i open
eclipse after a project was created, i get this error:
Unable to create view: NOT_SUPPORTED_ERR: The implementation does not
support the requested type of object or operation.
please help me, im stuck on windows till i can get it running
(and so you now, i have eclipse pdt working fine on my i386 machine, just
not this AMD64 Laptop)
thanks to anyone who tries to help..
Re: Eclipse + 64-Bit Linux [message #220870 is a reply to message #220391] |
Wed, 11 July 2007 09:54 |
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
<snip>
> just not this AMD64 Laptop)
I am unsure whether this is the actual cause, but the typical problem
with eclipse on 64-bit is that you need a 64 bit java as well. I.e. if
you download that all-in-one package, check whether it is 32-bit or
64-bit and make sure you run it with the corresponding java.
HTH, H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGlKjWe+7xMGD3itQRAm03AJ4riUYeLZx9UaGYR0IYxjWntKq7hwCe OM4D
clRqb80yU/mMSWSZdZQ7lKE=
=A2cs
-----END PGP SIGNATURE-----
Current Time: Thu Apr 18 12:05:02 GMT 2024
Powered by FUDForum. Page generated in 0.04697 seconds
