Home » Newcomers » Newcomers » runtime workbench disables most plugins
runtime workbench disables most plugins [message #220233] |
Fri, 06 July 2007 14:10 |
Originally posted by: jverge.lycos.com
Hi, I was wondering why a huge number of my plugins get disabled when
forking a runtime workbench. Options that are available in th main
eclipse page aren't available in the forked one. For example I would like
to go new -> Example EMF Model Creation Wizard which, among many others,
disappears.
This is in v3.2.2, with jre1.5.0_12 and compiler compliance set to 5.
These plugins (EMF, GMF, oAW and others) are all enabled and work fine in
the main eclipse, so why would they get disabled in the forked one?
No doubt this is a noob question, but I've looked and can't figure it out.
Thanks for any help...
Re: runtime workbench disables most plugins [message #220241 is a reply to message #220233] |
Fri, 06 July 2007 14:49 |
Jeff,
Usually the Error log will show information about why plugins are
failing to activate.
> like
> others, disappears.
> in the main eclipse, so why would they get disabled in the forked one?
> out.
Re: runtime workbench disables most plugins [message #220254 is a reply to message #220241] |
Fri, 06 July 2007 16:00 |
Thanks Ed, I think the info is here for someone who knows how to decipher
it.
Could it be because eclipse itself is running on jre 1.6? I didn't think
that
would be an issue but now I'm not so sure. Would be easy enough to resolve
if that were it...
Jeff
The error log in its entirety is:
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6d868448, pid=2356,
tid=3672
# Java VM: Java HotSpot(TM) Client VM (1.6.0_01-b06 mixed mode, sharing)
# Problematic frame:
# V
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x02be4000): VMThread
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000c
Registers:
EAX=0x0000000c, EBX=0x0a0e1280, ECX=0x00001e00, EDX=0x00040f82
ESP=0x02d1f9cc, EBP=0x27b14ef0, ESI=0x0a0d9a80, EDI=0x27b14ee8
EIP=0x6d868448, EFLAGS=0x00010206
Top of Stack: (sp=0x02d1f9cc)
0x02d1f9cc: 00389b90 6d9c6b3c 6d9c6b3c 090c0000
0x02d1f9dc: 6d8f64aa 0a0d0080 6d8f68aa 00000003
0x02d1f9ec: 6d961502 6d9e0f28 6d9c6b3c 00389b90
0x02d1f9fc: 00389b90 6d92b03a 6d9c6b3c 00000000
0x02d1fa0c: 6d9c6b3c 6d9c6b3c 6d85c4e1 00000001
0x02d1fa1c: 00000002 6d9c6b3c 6d9c6b3c 0038a450
0x02d1fa2c: 00389b90 090c0000 00000000 6d85e16b
0x02d1fa3c: 00000001 00000000 00000001 00000002
Instructions: (pc=0x6d868448)
0x6d868438: b7 4f 02 8d 1c 8e 3b f3 73 20 8b 06 85 c0 74 13
0x6d868448: 8b 10 83 e2 03 80 fa 03 74 09 56 e8 98 e3 08 00
Stack:
VM_Operation (0x057efb44): full generation collection, mode: safepoint,
requested by thread 0x2cad1c00
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x2cad1c00 JavaThread "Worker-26"
0x2c827c00 JavaThread "Worker-25"
0x04e0bc00 JavaThread "StandardManager[/viewer]" daemon
0x2c7cdc00 JavaThread "TP-Monitor" daemon
0x2c642c00 JavaThread "TP-Processor4" daemon
0x2c76e000 JavaThread "TP-Processor3" daemon
0x2c7f7000 JavaThread "TP-Processor2" daemon
0x2c9f5c00 JavaThread "TP-Processor1" daemon
0x2c81fc00 JavaThread "StandardManager[]" daemon
0x2c871800 JavaThread "Java2D Disposer" daemon
0x0308a000 JavaThread "Java indexing" daemon
0x030be400 JavaThread "Start Level Event Dispatcher" daemon
0x0313d800 JavaThread "Framework Event Dispatcher" daemon
0x02bfcc00 JavaThread "Low Memory Detector" daemon
0x02bf8000 JavaThread "CompilerThread0" daemon
0x02bf6c00 JavaThread "Attach Listener" daemon
0x02bf5c00 JavaThread "Signal Dispatcher" daemon
0x02bee400 JavaThread "Finalizer" daemon
0x02bed000 JavaThread "Reference Handler" daemon
0x00386400 JavaThread "main"
Other Threads:
=>0x02be4000 VMThread
0x02bff400 WatcherThread
VM state:at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: ()
Threads_lock - owner thread: 0x02be4000
[0x00384fd8/0x000006dc] Heap_lock - owner thread: 0x2cad1c00
Heap
def new generation total 6400K, used 379K [0x06960000, 0x07050000,
0x090c0000)
eden space 5696K, 6% used [0x06960000, 0x069bed88, 0x06ef0000)
from space 704K, 0% used [0x06ef0000, 0x06ef0000, 0x06fa0000)
to space 704K, 0% used [0x06fa0000, 0x06fa0000, 0x07050000)
tenured generation total 84672K, used 49279K [0x090c0000, 0x0e370000,
0x26960000)
the space 84672K, 58% used [0x090c0000, 0x0c0dfe58, 0x0c0e0000,
0x0e370000)
compacting perm gen total 55808K, used 55573K [0x26960000, 0x29fe0000,
0x2a960000)
the space 55808K, 99% used [0x26960000, 0x29fa5518, 0x29fa5600,
0x29fe0000)
ro space 8192K, 62% used [0x2a960000, 0x2ae5e4e8, 0x2ae5e600,
0x2b160000)
rw space 12288K, 52% used [0x2b160000, 0x2b7a0e78, 0x2b7a1000,
0x2bd60000)
Dynamic libraries:
0x00400000 - 0x00423000 C:\WINDOWS\system32\javaw.exe
0x7c900000 - 0x7c9b0000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f5000 C:\WINDOWS\system32\kernel32.dll
0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e70000 - 0x77f01000 C:\WINDOWS\system32\RPCRT4.dll
0x7e410000 - 0x7e4a0000 C:\WINDOWS\system32\USER32.dll
0x77f10000 - 0x77f57000 C:\WINDOWS\system32\GDI32.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre1.6.0_01\bin\msvcr71.dll
0x6d7c0000 - 0x6da07000 C:\Program
Files\Java\jre1.6.0_01\bin\client\jvm.dll
0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll
0x6d310000 - 0x6d318000 C:\Program Files\Java\jre1.6.0_01\bin\hpi.dll
0x76bf0000 - 0x76bfb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d770000 - 0x6d77c000 C:\Program Files\Java\jre1.6.0_01\bin\verify.dll
0x6d3b0000 - 0x6d3cf000 C:\Program Files\Java\jre1.6.0_01\bin\java.dll
0x6d7b0000 - 0x6d7bf000 C:\Program Files\Java\jre1.6.0_01\bin\zip.dll
0x6d570000 - 0x6d583000 C:\Program Files\Java\jre1.6.0_01\bin\net.dll
0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll
0x77c10000 - 0x77c68000 C:\WINDOWS\system32\msvcrt.dll
0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll
0x6d590000 - 0x6d599000 C:\Program Files\Java\jre1.6.0_01\bin\nio.dll
0x04ec0000 - 0x04f13000
C:\eclipse3.2.2\eclipse\configuration\org.eclipse.osgi\bundl es\377\1\.cp\swt-win32-3236.dll
0x774e0000 - 0x7761d000 C:\WINDOWS\system32\ole32.dll
0x773d0000 - 0x774d3000
C:\WINDOWS\WinSxS\X86_Microsoft.Windows.Common-Controls_6595 b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\COMCTL32.dll
0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll
0x763b0000 - 0x763f9000 C:\WINDOWS\system32\comdlg32.dll
0x7c9c0000 - 0x7d1d5000 C:\WINDOWS\system32\SHELL32.dll
0x77120000 - 0x771ac000 C:\WINDOWS\system32\OLEAUT32.dll
0x76390000 - 0x763ad000 C:\WINDOWS\system32\IMM32.dll
0x74d90000 - 0x74dfb000 C:\WINDOWS\system32\USP10.dll
0x771b0000 - 0x77256000 C:\WINDOWS\system32\WININET.dll
0x77a80000 - 0x77b14000 C:\WINDOWS\system32\CRYPT32.dll
0x77b20000 - 0x77b32000 C:\WINDOWS\system32\MSASN1.dll
0x75a70000 - 0x75a91000 C:\WINDOWS\system32\MSVFW32.dll
0x5d090000 - 0x5d12a000 C:\WINDOWS\system32\comctl32.dll
0x74720000 - 0x7476b000 C:\WINDOWS\system32\MSCTF.dll
0x5ad70000 - 0x5ada8000 C:\WINDOWS\system32\UxTheme.dll
0x74c80000 - 0x74cac000 C:\WINDOWS\system32\oleacc.dll
0x76080000 - 0x760e5000 C:\WINDOWS\system32\MSVCP60.dll
0x052c0000 - 0x052d3000
C:\eclipse3.2.2\eclipse\configuration\org.eclipse.osgi\bundl es\377\1\.cp\swt-gdip-win32-3236.dll
0x4ec50000 - 0x4edf3000
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144cc f1df_1.0.2600.2180_x-ww_522f9f82\gdiplus.dll
0x054b0000 - 0x05775000 C:\WINDOWS\system32\xpsp2res.dll
0x76380000 - 0x76385000 C:\WINDOWS\system32\msimg32.dll
0x05220000 - 0x0523a000 C:\Program Files\Dell\QuickSet\dadkeyb.dll
0x05290000 - 0x05298000
C:\eclipse3.2.2\eclipse\configuration\org.eclipse.osgi\bundl es\105\1\.cp\os\win32\x86\localfile_1_0_0.dll
0x71a50000 - 0x71a8f000 C:\WINDOWS\System32\mswsock.dll
0x76f20000 - 0x76f47000 C:\WINDOWS\system32\DNSAPI.dll
0x76fb0000 - 0x76fb8000 C:\WINDOWS\System32\winrnr.dll
0x76f60000 - 0x76f8c000 C:\WINDOWS\system32\WLDAP32.dll
0x76fc0000 - 0x76fc6000 C:\WINDOWS\system32\rasadhlp.dll
0x058d0000 - 0x058f8000 C:\WINDOWS\system32\rsaenh.dll
0x769c0000 - 0x76a73000 C:\WINDOWS\system32\USERENV.dll
0x5b860000 - 0x5b8b4000 C:\WINDOWS\system32\netapi32.dll
0x6d000000 - 0x6d1c3000 C:\Program Files\Java\jre1.6.0_01\bin\awt.dll
0x73000000 - 0x73026000 C:\WINDOWS\system32\WINSPOOL.DRV
0x73760000 - 0x737a9000 C:\WINDOWS\system32\ddraw.dll
0x73bc0000 - 0x73bc6000 C:\WINDOWS\system32\DCIMAN32.dll
0x6d2b0000 - 0x6d303000 C:\Program
Files\Java\jre1.6.0_01\bin\fontmanager.dll
0x662b0000 - 0x66308000 C:\WINDOWS\system32\hnetcfg.dll
0x71a90000 - 0x71a98000 C:\WINDOWS\System32\wshtcpip.dll
0x76fd0000 - 0x7704f000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77050000 - 0x77115000 C:\WINDOWS\system32\COMRes.dll
0x77c00000 - 0x77c08000 C:\WINDOWS\system32\VERSION.dll
0x75cf0000 - 0x75d81000 C:\WINDOWS\system32\mlang.dll
VM Arguments:
jvm_args: -Xms40m -Xmx512m
java_command: C:\eclipse3.2.2\eclipse\startup.jar -os win32 -ws win32
-arch x86 -launcher C:\eclipse3.2.2\eclipse\eclipse.exe -name Eclipse
-showsplash 600 -exitdata d48_6c -clean -vm C:\WINDOWS\system32\javaw.exe
-vmargs -Xms40m -Xmx512m -jar C:\eclipse3.2.2\eclipse\startup.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\WBEM ;C:\Program
Files\ATI Technologies\ATI.ACE\
USERNAME=Administrator
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 72 Stepping 2, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 2 family 15, cmov, cx8, fxsr, mmx, sse, sse2, mmxext, 3dnowext,
3dnow, ht
Memory: 4k page, physical 1964004k(1161788k free), swap 4194303k(4100264k
free)
vm_info: Java HotSpot(TM) Client VM (1.6.0_01-b06) for windows-x86, built
on Mar 14 2007 00:24:02 by "java_re" with unknown MS VC++:1310
Re: runtime workbench disables most plugins [message #220272 is a reply to message #220254] |
Fri, 06 July 2007 16:28 |
Jeff,
I would have though 1.6/6.0 would be fine, but it's certainly worth
trying a different one. The Error Log view will typically explain why a
plugin is not activated. The information below looks like a JVM crash
though. It would be good to clear the log and start again to be sure
you are seeing the messages for the most recent invocation...
> decipher it.
> think that
> resolve
> if that were it...
> Thanks
> Jeff
> tid=3672
> # V
> Registers:
> Stack:
> safepoint, requested by thread 0x2cad1c00
> Other Threads:
> Heap
> 0x090c0000)
> 0x0e370000, 0x26960000)
> 0x0e370000)
> 0x29fe0000, 0x2a960000)
> 0x29fe0000)
> 0x2b160000)
> 0x2bd60000)
> Dynamic libraries:
> VM Arguments:
> C:\WINDOWS\system32\javaw.exe -vmargs -Xms40m -Xmx512m -jar
> OS=Windows_NT
> 3dnowext, 3dnow, ht
> 4194303k(4100264k free)
> built on Mar 14 2007 00:24:02 by "java_re" with unknown MS VC++:1310
Re: runtime workbench disables most plugins [message #220304 is a reply to message #220272] |
Fri, 06 July 2007 19:22 |
Hi again Ed. Yes, you are right, that error log was somthing else. Good
thing I'm in the newcomers' section.
The whole of the pde error log is huge so this is just the first few
lines, but every entry indicates org.eclipse.osgi as the common link
between them.
I have org.eclipse.osgi_3.2.2.R32x_v20070118.jar in my plugins folder and
just
for fun I overwrote it with a new one in case it had become corrputed or
something. I also played around with adding it to the build path, and got
the error message that it was included twice, which is a good thing I
guess...
Is there something I can download (and if so, where is it??) or do you have
any advice you can give me?
Sorry for the noob questions and thanks again for your help.
!SESSION 2007-07-06 14:27:31.546
eclipse.buildId=M20070212-1330
java.version=1.5.0_12
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_CA
Framework arguments: -product org.eclipse.sdk.ide -pdelaunch
Command-line arguments: -product org.eclipse.sdk.ide -data
C:\eclipse3.2.2\workspace\oaw/../runtime-EclipseApplication -dev
file:C:/eclipse3.2.2/workspace/oaw/.metadata/.plugins/org.ec lipse.pde.core/Eclipse
Application/dev.properties -pdelaunch -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 2 0 2007-07-06 14:27:38.890
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-07-06 14:27:38.890
!MESSAGE Bundle
update@plugins/org.eclipse.emf.common_2.3.0.v200706262000.jar was not
resolved.
!SUBENTRY 2 org.eclipse.emf.common 2 0 2007-07-06 14:27:38.890
!MESSAGE Missing required bundle org.eclipse.core.runtime_[3.3.0,4.0.0).
!MESSAGE Bundle
update@plugins/org.eclipse.emf.ecore_2.3.0.v200706262000.jar was not
resolved.
!SUBENTRY 2 org.eclipse.emf.ecore 2 0 2007-07-06 14:27:38.890
!MESSAGE Bundle
update@plugins/org.eclipse.emf.importer.ecore_2.3.0.v200706262000.jar was
not resolved.
!SUBENTRY 2 org.eclipse.emf.importer.ecore 2 0 2007-07-06 14:27:38.890
Re: runtime workbench disables most plugins [message #220312 is a reply to message #220304] |
Fri, 06 July 2007 19:39 |
Jeff,
Based on this information, it looks like maybe you are trying to run EMF
2.3 with Eclipse 3.2.x when it needs Eclipse 3.3.
> Good thing I'm in the newcomers' section.
> between them.
> and just
> or something. I also played around with adding it to the build path,
> and got the error message that it was included twice, which is a good
> thing I guess...
> have
> -clean
> root constraints are not resolved:
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> was not resolved.
Re: runtime workbench disables most plugins [message #220377 is a reply to message #220312] |
Fri, 06 July 2007 22:46 |
Yeah I knew about that but because I also have an earlier EMF i didn't
think it
would cause any many problems. I've had difficulty uninstalling that
plugin
but left it because there were no problems until starting a second eclipse.
Looks like the runtime is less forgiving. And i've got some cleanup to do.
Thanks for your time Ed.
Current Time: Thu Apr 25 12:08:31 GMT 2024
Powered by FUDForum. Page generated in 0.08634 seconds
