Upgrate to eclipse 3.3 [message #219803] |
Wed, 04 July 2007 16:24 |
Originally posted by: shaulch.gmail.com
I'm trying to upgrade eclipse 3.2.2 to 3.3 via software updates but it
doesn't find any updates .
Whats the problem ?
Shaul.
Re: Upgrate to eclipse 3.3 [message #219811 is a reply to message #219803] |
Wed, 04 July 2007 16:40 |
Originally posted by: dmsubs.NOSPAM.consertum.com
Perhaps the clue is in what you wrote...
You are trying to *upgrade* using the *update* mechanism...
To "upgrade", you should perform a fresh install of the new release.
Derek
shaul wrote:
> Whats the problem ?
> Thanks
> Shaul.
Re: Upgrate to eclipse 3.3 [message #219904 is a reply to message #219811] |
Thu, 05 July 2007 05:43 |
Thank but how can i import the plugin's ? or should i re-install it ?
Re: Upgrate to eclipse 3.3 [message #219920 is a reply to message #219904] |
Thu, 05 July 2007 07:08 |
You must install. It is not possible to 'update' a 3.2 installation to 3.3.
Derek
Re: Upgrate to eclipse 3.3 [message #220249 is a reply to message #219920] |
Fri, 06 July 2007 15:43 |
Originally posted by: kwarner.uneedspeed.net
Ouch! That means dump everything and reinstall EVERYTHING????
Re: Upgrate to eclipse 3.3 [message #220343 is a reply to message #220249] |
Fri, 06 July 2007 20:25 |
Originally posted by: eclipse5.rizzoweb.com
DemonDuck wrote:
>> 3.3.
Download new ZIP, extract to new location, point to existing workspace.
Unless you have third-party plugins (which would need to be installed
into the new Eclipse installation), this should be pretty straightforward.
I've done it about a dozen times over the past few years and it never
caused me much trouble.
Eric
FUDForum. Page generated in 0.08927 seconds
