Installation won't start [message #219277] |
Mon, 02 July 2007 21:34 |
Originally posted by: kenneth.reeves.verizon.com
All,
I am trying to install Eclipse Europa. I just downloaded it. The
installation program initiates, the nice screen stating eclipse europa
with the copyright appears and then.....nothing. I'm running Windows XP
SP2. I have searched this forum and read part of the installation guide.
But I didn't see an answer. Any ideas?
Ken
Re: Installation won't start [message #219352 is a reply to message #219323] |
Tue, 03 July 2007 06:18 |
Originally posted by: mknauer.innoopract.com
Mark Dexter wrote:
> Ken Reeves wrote:
>> All,
>> guide. But I didn't see an answer. Any ideas?
>> Thanks,
>> Ken
> First thing to check is that it unzipped correctly. Did you use the
> Windows built-in zip or a third-party program? Mark Dexter
This may be caused by the line
-Dosgi.bundlefile.limit=100
in the eclipse.ini file. Could you please remove that line and try it again?
Markus
Re: Installation won't start [message #219493 is a reply to message #219277] |
Tue, 03 July 2007 13:21 |
Originally posted by: eclipse5.rizzoweb.com
Ken Reeves wrote:
> All,
Does the splash screen stay visible, or go away? Does the progress bar
at the bottom of the splash screen advance at all? Did it ever prompt
you for a workspace location?
Can you find any .log in the Eclipse directory?
Finally, try specifying the exact JVM you want to run Eclipse with, by
adding something like the following to your eclipse.ini file (note that
line breaks are critical):
-vm
D:\Java\JDK\6.0\bin\javaw.exe
-vmargs
-Xms40m
-Xmx512m
Hope this helps,
Eric
Re: Installation won't start [message #219514 is a reply to message #219493] |
Tue, 03 July 2007 14:02 |
I found the log file. I was running 1.3.16 I updated my classpath to 1.6
and it installed just fine. Thanks for all of your help.
Ken
FUDForum. Page generated in 0.28289 seconds
