Re: Eclispe 3.3 Crashes On Startup [message #219360 is a reply to message #219269] |
Tue, 03 July 2007 06:23 |
Originally posted by: mknauer.innoopract.com
Tony wrote:
> Hi All,
> After downloading either Eclispe for Java Developers or for J2EE and
> installing it crashes when launched. It comes up with error that it cannot
> access memory at location 0. I tried setting java_home to Sun jdk 1.5 and
> that did not fix the problem. It also occurs with Sun jdk 1.6.0_02. I am
> using Windows XP SP2 for my OS.
> Any ideas?
> Thx,
> -Tony
Same as in the next thread 'Installation won't start'.
* Could you first check the integrity of the download ZIP?
* Did it unzip correctly? The Windows XP integrated zip has sometimes
problems with long filenames.
* If all that didn't help, try removing the -Dosgi.bundlefile.limit=100 from
the eclise.ini file.
Please let us know, if any of these solved your problem.
Markus
FUDForum. Page generated in 0.07691 seconds
