Error message occurs while starting Eclipse [message #217545] |
Sat, 23 June 2007 16:07 |
Originally posted by: eclipse.slashdevslashnull.org
I'm running Eclipse under SuSE Linux 10.2 64-bit version on an AMD-64. When
I start Eclipse I get the following error as a pop-up window:
"Error notifying a preference change listener. Check log for details"
This error allows me to click on a button and keep going. Unfortunately it
re-occurs about 100 times but after the final one Eclipse does come up and
run. I'm hoping that someone can tell me what to do to clear this error.
I've appended some of my log information. The "Null Pointer Exception" seems
to repeat over and over again (perhaps coinciding with the number of times
I get the previous mentioned "Error Notification").
My Eclipse log information:
!SESSION 2007-06-23
11:31:11.977 -----------------------------------------------
eclipse.buildId=M20060921-0945
java.version=1.5.0_10
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch
x86_64 -data /home/jdowd/.eclipse
This is a continuation of log file /home/jdowd/.eclipse/.metadata/.bak_0.log
Created Time: 2007-06-23 11:31:52.714
!ENTRY org.eclipse.ui.workbench 4 2 2007-06-23 11:31:52.714
!MESSAGE Problems occurred when invoking code from
plug-in: "org.eclipse.ui.workbench".
!STACK 0
org.eclipse.cdt.internal.ui.text.CTextTools.adaptToPreferenc eChange(CTextTools.java:238)
org.eclipse.cdt.internal.ui.text.CTextTools$PreferenceListen er.propertyChange(CTextTools.java:38)
org.eclipse.ui.preferences.ScopedPreferenceStore$3.run(Scope dPreferenceStore.java:372)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.ui.preferences.ScopedPreferenceStore.firePropert yChangeEvent(ScopedPreferenceStore.java:369)
org.eclipse.ui.preferences.ScopedPreferenceStore.setToDefaul t(ScopedPreferenceStore.java:663)
org.eclipse.ui.texteditor.MarkerAnnotationPreferences.useAnn otationsPreferencePage(MarkerAnnotationPreferences.java:135)
org.eclipse.ui.editors.text.EditorsUI.useAnnotationsPreferen cePage(EditorsUI.java:99)
org.eclipse.cdt.ui.CUIPreferenceInitializer.initializeDefaul tPreferences(CUIPreferenceInitializer.java:49)
org.eclipse.core.internal.preferences.PreferenceServiceRegis tryHelper.runInitializer(PreferenceServiceRegistryHelper.jav a:276)
org.eclipse.core.internal.preferences.PreferenceServiceRegis tryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelp er.java:130)
org.eclipse.core.internal.preferences.PreferencesService.app lyRuntimeDefaults(PreferencesService.java:337)
org.eclipse.core.internal.preferences.DefaultPreferences.app lyRuntimeDefaults(DefaultPreferences.java:162)
org.eclipse.core.internal.preferences.DefaultPreferences.loa dDefaults(DefaultPreferences.java:231)
org.eclipse.core.internal.preferences.DefaultPreferences.loa d(DefaultPreferences.java:227)
org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:307)
org.eclipse.core.internal.preferences.EclipsePreferences.int ernalNode(EclipsePreferences.java:543)
org.eclipse.core.internal.preferences.EclipsePreferences.nod e(EclipsePreferences.java:662)
org.eclipse.core.internal.preferences.AbstractScope.getNode( AbstractScope.java:38)
org.eclipse.core.runtime.preferences.DefaultScope.getNode(De faultScope.java:67)
org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultP references(ScopedPreferenceStore.java:248)
org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferen ceNodes(ScopedPreferenceStore.java:282)
org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet (ScopedPreferenceStore.java:472)
org.eclipse.ui.preferences.ScopedPreferenceStore.getString(S copedPreferenceStore.java:532)
org.eclipse.jface.preference.PreferenceConverter.getColor(Pr eferenceConverter.java:204)
org.eclipse.cdt.internal.ui.text.AbstractCScanner.addToken(A bstractCScanner.java:96)
org.eclipse.cdt.internal.ui.text.AbstractCScanner.initialize (AbstractCScanner.java:89)
org.eclipse.cdt.internal.ui.text.CCodeScanner.<init>(CCodeScanner.java:59)
at org.eclipse.cdt.internal.ui.text.CTextTools.<init>(CTextTools.java:93)
at org.eclipse.cdt.ui.CUIPlugin.getTextTools(CUIPlugin.java:400 )
org.eclipse.cdt.internal.ui.editor.CEditor.initializeEditor( CEditor.java:225)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.<init >(AbstractDecoratedTextEditor.java:269)
at org.eclipse.ui.editors.text.TextEditor.<init>(TextEditor.java:51)
at org.eclipse.cdt.internal.ui.editor.CEditor.<init>(CEditor.java:218)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:242)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:238)
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:231)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:909)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:549)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1446)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.ja va:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:1001)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2843)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1936)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2857)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 805)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1681 )
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1421)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1679)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 650)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1529 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1473)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:702)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Error message occurs while starting Eclipse [message #217561 is a reply to message #217545] |
Sat, 23 June 2007 16:42 |
> !SESSION 2007-06-23
> !STACK 0
> java.lang.NullPointerException
> at
Since the problem is coming from the CDT, you might try posting in the
CDT newsgroup if you don't get any response here.
Eric
FUDForum. Page generated in 0.09417 seconds
