Problem: SQLSTATE: 42704 in DataBase exporer [message #216677] |
Tue, 19 June 2007 12:53 |
Originally posted by: jmphelan.texas.net
Working through the tutorial "Kick-start your Java apps, Part 1" from
developer works. One section works with a DB2 express C-9 sample
database. Instructions are to right click on a table and select "data ->
Sample Content". I am getting the SQL error:
com.ibm.db2.jcc.b.SqlException: DB2 SQL error: SQLCODE: -204, SQLSTATE:
42704, SQLERRMC: SQLJ.EMPLOYEE. This error is "An undefined object or
constraint name was detected." The object name is "Sample Contents" from
the left pane. I could use some help on how to proceed from here.
Re: Problem: SQLSTATE: 42704 in DataBase exporer [message #216689 is a reply to message #216677] |
Tue, 19 June 2007 13:09 |
"Looking at the data->edit" selection I can see more detail, but this
looks like a NPE caused by the previously mentioned error, please comment:
org.eclipse.wst.rdb.data.internal.ui.editor.TableDataTableCu rsor.registerCellEditorsListener(TableDataTableCursor.java:1 08)
org.eclipse.wst.rdb.data.internal.ui.editor.TableDataTableCu rsor. <init>(TableDataTableCursor.java:39)
org.eclipse.wst.rdb.data.internal.ui.editor.TableDataTableCu rsorExternalEditingSupport. <init>(TableDataTableCursorExternalEditingSupport.java:46)
org.eclipse.wst.rdb.data.internal.ui.editor.TableDataEditor. createPartControl(TableDataEditor.java:111)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:596)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2595)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2528)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2520)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2505)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2500)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2477)
org.eclipse.wst.rdb.data.internal.ui.editor.EditTableDataAct ion.run(EditTableDataAction.java:42)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
FUDForum. Page generated in 0.04408 seconds
