Re: JRE 6.0 but 5.0 compliance [message #216714 is a reply to message #216599] |
Tue, 19 June 2007 16:47 |
Originally posted by: eclipse5.rizzoweb.com
Ryan Fong wrote:
> G'day mates! I'm using Eclipse sdk 3.3rc4. I'd like our team to install
> JDK 6.0 but have the code comply to 5.0 for now. I set the workspace
> compiler compliance to 5.0 but it allowed me to use javax.swing.SwingWorker,
> which is new in JDK6.0. Is there a way to enforce the 5.0 API? Flagging
> this as a compile error would be great.
You need to specify that a Java 5 JDK/JRE be used, either at the
workspace level or on a per-project basis. Set up the Java 5 JRE under
Preferences > Java > Installed JREs, then you can select it in the
project properties (and check in the .classpath file to your source
control system).
Hope this helps,
Eric
FUDForum. Page generated in 0.08282 seconds
