Home » Newcomers » Newcomers » Make Search case-insenstive by default
Make Search case-insenstive by default [message #215572] Wed, 13 June 2007 18:21 Go to next message
Originally posted by: JesseAldridge.gmail.com
I'd like to make the Search->File option default to a case-insensitive
search. Every time I restart Eclipse, the Case-Sensitive box is checked
by default. Any suggestions?
Re: Make Search case-insenstive by default [message #215600 is a reply to message #215572] Wed, 13 June 2007 20:39 Go to previous messageGo to next message
Jesse,
I don't see a preference for this, but I wonder what the Customize...
button does? Maybe that saves the choices?
> checked by default. Any suggestions?
Re: Make Search case-insenstive by default [message #215675 is a reply to message #215600] Thu, 14 June 2007 10:07 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
Ed Merks wrote:
> Jesse,
> button does?
Don't be afraid - click it and you'll see what it does ;-) There's no
relation to how a search is performed.
Dani
>> case-insensitive search. Every time I restart Eclipse, the
>> Case-Sensitive box is checked by default. Any suggestions?
Re: Make Search case-insenstive by default [message #215683 is a reply to message #215572] Thu, 14 June 2007 10:16 Go to previous messageGo to next message
> checked by default.
I don't see this behavior (using 3.3.RC4). Note that like all Eclipse
dialogs it remembers the values of the last successful usage i.e. if you
open the dialog, change some options and close it again it won't store
your changes but if you adjust the options and then perform a search it
will keep your last used settings. If that doesn't work for you using
3.3 RC4 or newer then please file a bug report against Platform Search.
Dani
> Any suggestions?
Re: Make Search case-insenstive by default [message #215729 is a reply to message #215675] Thu, 14 June 2007 13:59 Go to previous messageGo to next message
Dani,
I did and a dialog with check boxes came up. But it wasn't clear what
that dialog did either. Silly me. I see now that it lets you hide
pages you don't want to see. :-)
Daniel Megert wrote:
> Ed Merks wrote:
>> Jesse,
>> button does?
> Dani
Re: Make Search case-insenstive by default [message #215871 is a reply to message #215572] Thu, 14 June 2007 19:34 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Jesse Aldridge" <JesseAldridge@gmail.com> wrote in message
news:e8c96ba23e378e622e4a40a8d17ec2f5$1@www.eclipse.org...
Is it possible that your workspace prefs are read-only (e.g., because of a
version control system or a shared file system)?
Re: Make Search case-insenstive by default [message #215916 is a reply to message #215683] Thu, 14 June 2007 23:36 Go to previous message
Originally posted by: jessealdridge.gmail.com
I was using 3.2.2. Upgrading to the suggestion version fixed my problem.
Thanks!
Previous Topic:How to set up a JAVA_HOME based JRE ?
Next Topic:Code Migration Planning and Assessment Workbench for Visual Basic
Current Time: Tue Apr 16 19:03:07 GMT 2024
Powered by FUDForum. Page generated in 1.52189 seconds
