An exception come out when using jfreechart in eclipse 3.1 [message #215382] |
Wed, 13 June 2007 05:35 |
Originally posted by: ludinghong1981.163.com
I want to use jfreechart(a software for charting) in eclipse3.1,then when
I try to open a chart,a exception comes out,described as follow:
Unhandled event loop exception
Reason:
org.eclipse.swt.graphics.GC.getDevice()Lorg/eclipse/swt/grap hics/Device;
then I find the org.eclipse.swt.graphics.GC class in eclipse's help. I
didn't
find the getDevice() function in the GC.
I am so Confused ,any one can help me? thank you!
Re: An exception come out when using jfreechart in eclipse 3.1 [message #215451 is a reply to message #215382] |
Wed, 13 June 2007 11:29 |
Lu,
Without a stack trace (which you can get from the Error Log view or from
<workspace>/.metadata/.log), you've likely not provided enough
information for anyone to guess at which might be going wrong. You
likely should be asking the supplier of jfreechart or look into using
BIRT instead: http://www.eclipse.org/birt/phoenix/
> when I try to open a chart,a exception comes out,described as follow:
> Reason:
> didn't find the getDevice() function in the GC. I am so Confused ,any
FUDForum. Page generated in 0.08779 seconds
