Re: Toolbars disappeared [message #215444 is a reply to message #215374] |
Wed, 13 June 2007 11:27 |
Zachary,
Never having worked with the CDT project, I can only guess. Is it
possible that creating the C++ project turned to a new perspective and
you just need to use the tab on the upper right to turn back to a
different perspective?
Zachary Turner wrote:
> I just installed Europa and created a C++ project and all the toolbars
> disappeared. How do I get them back? All I have is the menu with File,
> Edit, Refactor, etc. but no toolbars
Re: Toolbars disappeared [message #215460 is a reply to message #215374] |
Wed, 13 June 2007 12:14 |
Originally posted by: jakub.jurkiewicz.gmail.com
Maybe, by accident, you hide the toolbar? Go to Window->Show Toolbar.
Hope this helps,
Jakub Jurkiewicz
http://eclipser-blog.blogspot.com/
Re: Toolbars disappeared [message #215617 is a reply to message #215444] |
Wed, 13 June 2007 23:36 |
Zachary Turner Messages: 12 Registered: July 2009 |
Junior Member |
Well, somehow I got them back. I changed to Java Perspective, then they
appeared, then I changed back to C++ Perspective, and they stayed. Lucky
I tried this, I never program in Java so it's not normally something I
would do.
To answer your question, opening a C++ project does indeed switch to a new
perspective, but originally toolbars existed in that perspective. Then
when I switched to Debug perspective and came back to C++ perspective,
they were gone. Switching to Java then back to C++ seemed to fix it.
On Wed, 13 Jun 2007 07:27:18 -0400, Ed Merks wrote:
> Zachary,
FUDForum. Page generated in 0.07956 seconds
