Re: Problem Reading Cheat Sheet instructions [message #213254 is a reply to message #213229] |
Fri, 01 June 2007 06:54 |
Originally posted by: newsgroups.pellaton.li
This is a known issue in Eclipse 3.2: Cheat sheets are composed of so
called 'items' and 'subitems'. For some reason, the subitems are only
displayed if all the previous items are marked as 'done'.
So, to see the subitems, run through the cheat sheet and mark every
step as 'done'. When you arrive at the point you mentioned, all
subitems should become visible.
AFAIK this is solved in the upcoming 3.3 release...
HTH
Michael
Roy wrote:
> I am running version 3.2.
> The problem applies to all cheat sheets I have tried but the current one I
> am looking at is from the welcome screen, Creating an Eclipse Plugin. In
> the step Modify the plug-in there is the following instruction
> To modify your com.example.helloworld plug-in, perform the following
> steps:
> The problem is that there are no steps displayed after the colon in the
> shaded area.
FUDForum. Page generated in 0.03277 seconds
