Installing java help in eclipse [message #211895] |
Thu, 24 May 2007 12:50 |
Originally posted by: ciccio4242.libero.it
I've downloaded java 6 SE help from java.sun.com, and I'd like to have
it integrated into eclipse, i.e. while I'm editing and I press F1 on the
word String it would be great if the Java help for String class would
show up in the help pane.
How can I do that???
Ciccio
Re: Installing java help in eclipse [message #211902 is a reply to message #211895] |
Thu, 24 May 2007 13:16 |
Originally posted by: nugaee.SPAMtlen.pl
ciccio wrote:
I don't think this is possible.
If you can use Java SDK you can get much more better support and
integration (context help browsing through system libraries code etc.)
if you need to use your local copy of javadoc you can attach it to your
project in rt.jar properties in your project. then this documentation
can be viewed in JavaDoc view by clicking specific class or method in editor
hope this help
bartosz michalik
Re: Installing java help in eclipse [message #211932 is a reply to message #211902] |
Thu, 24 May 2007 14:30 |
What shoud I download? Right now I have the one at
http://java.sun.com/javase/6/docs/
Re: Installing java help in eclipse [message #212017 is a reply to message #211895] |
Thu, 24 May 2007 22:27 |
Originally posted by: eclipse5.rizzoweb.com
ciccio wrote:
Shift+F2 is the keyboard shortcut to open the Javadoc in your browser.
Usually it does not require any special set-up if you are using a JDK
instead of a JRE.
Hope this helps,
Eric
Re: Installing java help in eclipse [message #212435 is a reply to message #212017] |
Mon, 28 May 2007 10:20 |
Does not work.
When I put my mouse over (for example) String class I have the message:
"java.lang.String
Note: This element neither has attached source nor attached Javadoc and
hence no information could be found."
Any hint?
Re: Installing java help in eclipse [message #212442 is a reply to message #212435] |
Mon, 28 May 2007 12:17 |
Originally posted by: jakub.jurkiewicz.gmail.com
Try:
Window -> Preferences, in the tree on the left go Java->Installed JREs,
choose the jre you're using and click "Edit" button on the right. There
should new window be opened, click "Javadoc Location" button and point
to the location with the javadoc.
I've got it set to (I guess it's by default):
http://java.sun.com/javase/6/docs/api/
Why don't you try this?
Hope this helps,
Jakub Jurkiewicz
http://eclipser-blog.blogspot.com/
ciccio wrote::
>>> have it integrated into eclipse,
> Does not work.
> "java.lang.String
> Any hint?
Re: Installing java help in eclipse [message #212458 is a reply to message #212442] |
Mon, 28 May 2007 13:32 |
Jakub Jurkiewicz wrote:
> Window -> Preferences, in the tree on the left go Java->Installed JREs,[...]
Wow: here's what I've been searching for!
You've lost your bet :-)
I did: I set javadocs rt.jar properties to my downloaded copy of the
above. Finally it works.
> Hope this helps,
It does. Thanks a lot for your help.
Ciao
Re: Installing java help in eclipse [message #212655 is a reply to message #212458] |
Tue, 29 May 2007 13:12 |
>> JREs,[...]
>> Hope this helps,
You should also know that if you use a full JDK instead of just a JRE,
Eclipse will usually find the source and Javadoc automatically without
having to specify them yourself.
Hope this helps,
Eric
FUDForum. Page generated in 0.04068 seconds
