Can't start Eclipse after reinstall [message #211135] |
Thu, 17 May 2007 20:34 |
Originally posted by: jcmdass.gmail.com
I just reinstalled Eclipse from the Ubuntu repository, because I wanted a
clean install, but now I can't start Eclipse any longer.
It comes up with an error message which points me to a log file.
The log file contains this:
http://nopaste.info/068d321cae.html
I hope somebody knows, what this means :(
regards jannes
Re: Can't start Eclipse after reinstall [message #211192 is a reply to message #211135] |
Fri, 18 May 2007 01:35 |
Originally posted by: eclipse5.rizzoweb.com
Jannes Meyer wrote:
The log says that it is using the GCJ JVM. You need to specify Eclipse
to use the Sun JVM instead.
Hope this helps,
Eric
Re: Can't start Eclipse after reinstall [message #211216 is a reply to message #211192] |
Fri, 18 May 2007 11:21 |
> Jannes Meyer wrote:
> Hope this helps,
> Eric
Thanks for your reply, but changing the jvm didn't change much.
I still get the same error log (as far as I can see).
Here is the new logfile: http://nopaste.info/1694748fee.html
It still complains about missing NLS messages (what is this?) and
some other errors, but in line 3 and 4 you can see that the sun java 1.6 is
used.
Regards, Jannes
Re: Can't start Eclipse after reinstall [message #211282 is a reply to message #211135] |
Fri, 18 May 2007 16:10 |
Originally posted by: wharley.bea.com
"Jannes Meyer" <jcmdass@gmail.com> wrote in message
news:f2ie7p$fjq$1@build.eclipse.org...
To reinstall, you need to either completely delete the old installation
first, or install to a different location. Could that be the issue?
Re: Can't start Eclipse after reinstall [message #211369 is a reply to message #211216] |
Sat, 19 May 2007 21:26 |
Originally posted by: wegener.cboenospam.com
Jannes Meyer wrote:
>> Jannes Meyer wrote:
>>> Hi,
>> Hope this helps,
>> Eric
> used.
> Regards, Jannes
You indicate that you are installing Eclipse from the Ubuntu repository.
This method of installing is not supported by Eclipse. My guess is
that who ever created the Eclipse package for Ubuntu didn't pick up the
appropriate language files, or you need to install additional packages
to get the language files. You might want to try contacting the
maintainer of the Ubuntu Eclipse package. Of simply installing Eclipse
by downloading directly from the Eclipse site.
Re: Can't start Eclipse after reinstall [message #211463 is a reply to message #211369] |
Mon, 21 May 2007 12:14 |
Thank you for your answer. I found out, that this Bug has already been
reported to the Ubuntu Bugtracker.
https://bugs.launchpad.net/ubuntu/+source/eclipse/+bug/10958 3
I left a comment there. So if anyone else here is experiencing the same
problem, please also post your log output there, maybe it helps.
After installing Eclipse from the official homepage, it works fine
here. Thank you!
FUDForum. Page generated in 0.04626 seconds
