Trouble using CDT with Eclipse [message #211017] |
Wed, 16 May 2007 17:18 |
Originally posted by: stoopingcrane.yahoo.com
I'm using Eclipse for the first time... got the SDK, then got the CDT
thro' Help->Software Updates... and thro' Castillo.
Started by setting the C/C++ perspective, then set up the project as usual
(similar to what's in the Help) for managed make C++. All's well and good
so far, then I save my Hello World program and try to build it... here's
what I get...
**** Build of configuration Debug for project Project1 ****
Build error
(Exec error:Launching failed)
Also, there was a warning listed in the Problems section about a missing
parser, involving a file spec.cpp when I started writing the program,
disappeared when I did the build.
Could any one please help me out? Thanks a lot.
Re: Trouble using CDT with Eclipse [message #211036 is a reply to message #211017] |
Wed, 16 May 2007 18:57 |
Originally posted by: my.exmpl.com
Anoop skrev:
> Hi
> usual (similar to what's in the Help) for managed make C++. All's well
> and good so far, then I save my Hello World program and try to build
> it... here's what I get...
> Build error
you need cygwin or migwin installed on your system and PATH pointing to
c:\cygwin\bin directory
Re: Trouble using CDT with Eclipse [message #211200 is a reply to message #211036] |
Fri, 18 May 2007 10:32 |
Thanks a lot for the help. I got and installed Cygwin, the build works and
I see the binaries now, but when I try to execute them, I get an error:
"This application failed to execute because cygwin1.dll was not found,
reinstalling the application may fix the problem"
This does not make sense to me as C:/Cygwin/bin is in PATH and cygwin1.dll
is in the bin folder. I tried copying the dll to the Eclipse folders,
without success.
Any help would be greatly appreciated.
FUDForum. Page generated in 0.08283 seconds
