Compiler - Java version used [message #210981] |
Wed, 16 May 2007 13:22 |
Originally posted by: evaandoli.dodo.com.au
Do eclipse have an internal compiler or does it use a JDK on the local
machine ?
I assume its internal as you never set the JDK location only the JRE.
If so then what level is it compiling to ? as in Java 1.4, Java 5 Java 6
etc.
How do you set this ?
Stu
Re: Compiler - Java version used [message #211052 is a reply to message #211007] |
Wed, 16 May 2007 19:02 |
Originally posted by: eclipse5.rizzoweb.com
Darin Swanson wrote:
> Internal compiler.
> Start with Window>Preferences>Java>Compiler
And note that it can be overridden on a per-project basis if you want.
Right-click on an individual Project and choose Properties > Java Compiler.
Hope this helps,
Eric
FUDForum. Page generated in 0.08247 seconds
