Home » Eclipse Projects » GEF » Active Editor ?
Active Editor ? [message #209656] Fri, 17 February 2006 12:41 Go to next message
When i've opened multiple instances of my GEF editor
i want to get access to the active model. When i switch
to another instance how do i get the active editor and model in GEF ?
Thanks in advance for any answer.
Re: Active Editor ? [message #210795 is a reply to message #209656] Mon, 06 March 2006 05:39 Go to previous messageGo to next message
Originally posted by: rudolf.pischek.cleverlance.com
IWorkbenchPage has IEditorPart getActiveEditor(), (it is active editor on page). From st extends EditorPart you can try getSite().getPage().getActiveEditor().
Re: Active Editor ? [message #210819 is a reply to message #210795] Mon, 06 March 2006 06:38 Go to previous message
Thanks for the answer. I found the solution too.
But i'm grateful for any reply regarding GEF.
Previous Topic:Image not visible on label
Next Topic:How to create filled and not filled triangle at the end points of connection
Current Time: Mon Jun 23 19:07:57 EDT 2025
Powered by FUDForum. Page generated in 0.03538 seconds
