Re: Build with Subclipse [message #207403 is a reply to message #207066] |
Wed, 25 April 2007 10:22 |
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Muttonhead schreef:
> Hi, I have just started using Subclipse in Eclipse 3.2. I've connected to my
> repository, into which I had imported my sources using subversion's command
> line client. I can check out my code and edit it no problem but what do I
> have to do to set up a build? Why doesnt Java Builder appear in Properties |
> Builders?
> My setup is: Eclipse 3.2.0, Subclipse 1.2.0, Subversion 1.4.2.
> Many thanks for any help,
You have to create the project as a Java project. So from the SVN
repository browser, you choose checkout, then ‘check out as new project
using the New Project Wizard’ and make it a Java project.
You can find Subversion and Subclipse specific mailinglists/newsgroups
over gmane.org, btw.
H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGLyvqe+7xMGD3itQRAj11AJ0XJqmRlt3VlgLuCF15qpS/m7PPiQCd Ejb8
RH0jQnGmW1UU4aaAGa4sp44=
=BXcW
-----END PGP SIGNATURE-----
Re: Build with Subclipse [message #207618 is a reply to message #207403] |
Wed, 25 April 2007 19:32 |
Eoin Killian Messages: 25 Registered: July 2009 |
Junior Member |
Thanks for the tip, that's solved my problem.
Eoin
"Hendrik Maryns" <hendrik_maryns@despammed.com> schrieb im Newsbeitrag
news:f0na1n$ir4$1@build.eclipse.org...
> Hash: SHA1
>> my
>> command
>> Properties |
>> Builders?
> repository browser, you choose checkout, then 'check out as new project
> using the New Project Wizard' and make it a Java project.
> H.
> Hendrik Maryns
> http://aouw.org
> =BXcW
FUDForum. Page generated in 0.08147 seconds
