eclipse error when exiting / checking out resources [message #204173] |
Tue, 10 April 2007 08:37 |
No real name Messages: 5 Registered: July 2009 |
Junior Member |
Hi all,
I haver recently re-installed eclipse (using callisto), and have run into
some problems. Whenever I shut down eclipse - even if I only just started
and closed it without doing anything else - I get "An error has occurred
while closing the workbench". Here's part of the log:
!SESSION 2007-04-10 10:28:12.867
eclipse.buildId=M20060629-1905
java.version=1.6.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=nl_BE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui.workbench 4 0 2007-04-10 10:28:29.667
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDispo sed(WorkbenchPartReference.java:153)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:101)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:933)
at org.eclipse.swt.widgets.Widget.release(Widget.java:743)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite. java:636)
at org.eclipse.swt.widgets.Widget.release(Widget.java:746)
<snipped>
!ENTRY org.eclipse.ui.workbench 4 2 2007-04-10 10:28:29.729
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.jface.text.Assert$AssertionFailedException: null argument;
at org.eclipse.jface.text.Assert.isNotNull(Assert.java:157)
at org.eclipse.jface.text.Assert.isNotNull(Assert.java:133)
org.eclipse.jface.text.contentassist.ContentAssistant.setRep eatedInvocationTrigger(ContentAssistant.java:2125)
org.eclipse.jdt.internal.ui.text.java.ContentAssistProcessor $2.assistSessionEnded(ContentAssistProcessor.java:192)
org.eclipse.jface.text.contentassist.ContentAssistant.fireSe ssionEndEvent(ContentAssistant.java:2008)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .hide(CompletionProposalPopup.java:868)
<snipped>
!ENTRY org.eclipse.team.core 4 0 2007-04-10 10:28:31.303
!MESSAGE Plug-in com.perforce.team.ui was unable to load class
com.perforce.team.ui.UITeamProvider.
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in com.perforce.team.ui was
unable to load class com.perforce.team.ui.UITeamProvider.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:165)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:149)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.team.core.RepositoryProvider.newProvider(Reposit oryProvider.java:661)
org.eclipse.team.core.RepositoryProvider.mapNewProvider(Repo sitoryProvider.java:163)
org.eclipse.team.core.RepositoryProvider.mapExistingProvider (RepositoryProvider.java:236)
org.eclipse.team.core.RepositoryProvider.getProvider(Reposit oryProvider.java:532)
<snipped>
Also, when I start typing in a file, the perforce plugin checks it out
correctly, but the file remains read only. After that, I cannot open the
file again on Windows 2000, although in the same situation on XP I can
open and edit it after closing it first.
Anyone have an idea what's going on here?
TIA,
zerofk
FUDForum. Page generated in 0.07847 seconds
