Problem launching eclipse in Linux [message #203628] |
Fri, 06 April 2007 06:16 |
Originally posted by: Muximori.gmail.com
I'm running kubuntu, I've installed the eclipse package from the standard
repository, however when I try to run it I get this message:
michael@michael:~$ eclipse
searching for compatible vm...
testing /usr/lib/jvm/java-gcj...not found
testing /usr/lib/kaffe/pthreads...not found
testing /usr/lib/jvm/java-1.5.0-sun...found
kdialog: Unknown option '--warning'.
kdialog: Use --help to get a list of available command line options.
any thoughts on why this is happening?
Re: Problem launching eclipse in Linux [message #203643 is a reply to message #203628] |
Fri, 06 April 2007 06:33 |
It appears that the eclipse laucher script is using incorrect syntax to
display a dialog box. I have no clue how KDialogue works, but can anyone
point me to the file I should be editing to fix this?
FUDForum. Page generated in 0.08081 seconds
