writing apllets using gef [message #203499] |
Tue, 22 November 2005 15:33 |
Originally posted by: benjamin.zeller.medien.uni-weimar.de
I am currently doing some research for a project at my university and
encoutered the following question I was not able to clarify totally.
Is it actually possible to write an applet for constructing uml-activity
diagramms using GEF in eclipse? In other words, is it possible to write an
application using GEF in eclipse and then export it somehow so I can run
the application as an applet on a webclient (browser)?
I am not quite sure if this is possible at all or if GEF is only a plugin
to be used from within eclipse.
Re: writing apllets using gef [message #203616 is a reply to message #203579] |
Wed, 23 November 2005 10:34 |
So is my assumption correct in so far as there is no way of using GEF in
Eclipse to easily build a uml-activity-diagramm editor running as an
applet in a browser.
Do I have to use Swing instead or is there any alternative to avoid
implementing every single graph editing functionaltiy by myself?
FUDForum. Page generated in 0.06280 seconds
