JUnit Called through Ant via Eclipse Hangs [message #202483] |
Fri, 30 March 2007 18:32 |
Chris Gardner Messages: 8 Registered: July 2009 |
Junior Member |
Environment: Windows XP Professional, Eclipse 3.2.2, Ant 1.6.5 (outside of
Eclipse)
I have a master build.xml file that orchestrates the build of 4 projects
(a, b, c, and d). There is also a build-common.xml that each project
build.xml imports. build-common.xml includes common targets, including a
test target that calls junit. The junit task doesn't override any forking
or classloading defaults. There is a third-party directory at the same
level as the individual project directories. Each project depends on jars
in third-party. The master build.xml and build-common.xml also live at the
same level as the project directories.
+ root
+ build-common.xml
+ build.xml
+ project.a
+ project.b
+ project.c
+ project.d
+ third-party
build.xml's basedir is set to "."
I call the master build.xml file in 3 ways: command line, Eclipse, and
CruiseControl. Note that I configured Eclipse to use an external ant 1.6.5
on my filesystem. All three calling methods successfully run the full
build, including the junit target for all projects.
I moved the master build.xml and build-common.xml to a new master-build
directory at the same level of the project directories and adjust the master
build.xml basedir to ".."
+ root
+ master-build
+ build-common.xml
+ build.xml
+ project.a
+ project.b
+ project.c
+ project.d
+ third-party
The compile and test will work from the command line, but when I call the
master build.xml through eclipse, one of the tests in project c hangs the
whole ant process. Up to the hanging test, project c compiles and the
tests pass. If I remove the hanging test and rerun, many of the tests will
run, but another test hangs. The CPU is still active. I also made my
ant.bat null out any CLASSPATH environment variable to no avail, though.
Any ideas as to why just moving locations (and adjusting location
properties) would do this?
Re: JUnit Called through Ant via Eclipse Hangs [message #202531 is a reply to message #202515] |
Sat, 31 March 2007 00:43 |
Junior Member |
I think I found it. I had to bump up MaxPermSize. Unfortunately, the JVM
wasn't telling me I needed to do it. I just made an educated guess.
"Chris Gardner" <chris.r.gardner@gmail.com> wrote in message
news:eujoqb$jl8$1@build.eclipse.org...
>I don't believe it's waiting for standard input.
> "Shankar Unni" <shankarunni@netscape.net> wrote in message
> news:eujo20$i1s$1@build.eclipse.org...
>>> the
>>> the
>>> whole ant process.
>> Is it trying to read, or even access, standard input, perhaps?
>> I used to run into problems like this with the Axis stub generator, which
>> tries to fiddle with standard input even though it really doesn't read
>> anything from there. (Putting it into the background on Linux would get
>> a SIGTSTP, but if you foreground it, it would run to completion
>> immediately).
FUDForum. Page generated in 0.08704 seconds
