Installation problem [message #202203] |
Thu, 29 March 2007 13:08 |
Originally posted by: davids.evertech.com.au
Downloaded eclipse-SDK-3.2.2-win32.zip and was extracting the contents to
my C: drive. However in the process of doing so I get the error message
"The system cannot find the file specified". Have downloaded twice from
the internet with the same result.
Attempted to grab all the missing stuff but the installation I cobbled
together doesn't have any tutorial help files; says "No standby content
available. No standby content part defined with id:
org.eclipse.platform.cheatsheet.". Not sure if this is connected with the
initial problem.
Anybody have similar experience?
David
Re: Installation problem [message #202214 is a reply to message #202203] |
Thu, 29 March 2007 13:36 |
Originally posted by: eclipse5.rizzoweb.com
> to my C: drive. However in the process of doing so I get the error
> message "The system cannot find the file specified".
What tool are you using to extract the ZIP? To what path on your drive
are you extracting it?
There have been lots of problems when people try to use the built-in ZIP
file handling in WindowsXP and if they try to extract to a long path on
their filesystem.
Hope this helps,
Eric
Re: Installation problem [message #202523 is a reply to message #202214] |
Fri, 30 March 2007 23:21 |
I have just opened the zip file by double clicking on it in Windows XP and
then dragged the Eclipse folder to the root of my C: drive. What is wrong
with that?
David S
FUDForum. Page generated in 0.08284 seconds
