Home » Language IDEs » C / C++ IDE (CDT) » Debuggin RMI
Debuggin RMI [message #201454] Wed, 12 September 2007 14:52 Go to next message
Originally posted by: someone.nospam.net
Evidently the folks at my work place use RMI (I am completely unfamiliar
with the concept) to start up the application I need to debug. Thus I need
to run some commands from the command line prior to invoking my application.
I looked around the debug dialog, but don't see anywhere I can do that from
within eclipse. How do I go about debugging? Do I need to manually open
another console and enter my commands or is there an easier automated way?
Also, can I debug as a local process or do I have to attach?
This is a C++ app btw, not a java app.
thanks
Re: Debuggin RMI [message #201461 is a reply to message #201454] Wed, 12 September 2007 15:27 Go to previous message
Originally posted by: dmsubs.NOSPAM.consertum.com
I'd suggest using a script/batch file that does your commands and finally
invokes gdb. Then replace the (gdb) debugger name with the name of your
script/batch file in the launch dialog.
Hope that's clear
Derek
> thanks
Previous Topic:Debugging JNI code under Linux ?
Next Topic:eclipse/cdt - I don't want build before launch
Current Time: Tue Jul 22 15:52:32 EDT 2025
Powered by FUDForum. Page generated in 0.03799 seconds
