Home » Modeling » EMF » Getting from an EPackage to the EPackage.Registry it was registered with
Getting from an EPackage to the EPackage.Registry it was registered with [message #1231898] Wed, 15 January 2014 17:38 Go to next message
Tassilo Horn is currently offline Tassilo HornFriend
Member
Hi all,
I'm currently in the process of migrating a library using EMF from using the global EPackage.Registry to using the local registries of ResourceSets. I only use dynamic model instances.
What I do is when loading an instance model, the ecore model's Resource has to be given, too. I create a new ResourceSet, register the ecore model's packages with the ResourceSet's local package registry, and then I load the instance model and add its Resource to the ResourceSet. I do not add the ecore model's Resource to the ResourceSet.
That works, however I'm facing some issues.
Basically, some operations of my library require that I can get to the EClasses defined in the ecore model from (a) EObjects in a conforming instance model and from (b) other EClasses defined in the same ecore model.
I can handle point (a), because from any EObject in an instance model I can navigate up containments until I hit the containing Resource, then get the ResourceSet, and then using that ResourceSet's local package registry to get to the EClasses.
However, I can't handle point (b) right now. As said, I only register the ecore model's packages with the ResourceSet's local package registry, but I do not add the ecore model's resource to the ResourceSet. Of course, I could do that, and then point (b) would be easy, but it would break if I wanted to use the same ecore model Resource in many ResourceSets (because adding a Resource to a ResourceSet removes it from the ResourceSet it was previously in).
So how do I get from an EPackage to the registry it was registered with? Or do I really need to add the Resource with the ecore model to the ResourceSet, and then load it multiple times into new Resources if I want to have many instance models?
Thanks a lot,
Tassilo
Re: Getting from an EPackage to the EPackage.Registry it was registered with [message #1233265 is a reply to message #1231898] Sun, 19 January 2014 04:28 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 15.01.2014 18:38, schrieb Tassilo Horn:
> Hi all,
This "load+add" should be done via:
resourceSet.getResource(URI, true);
Ok.
That is:
EClass eClass = instance.eClass();
That is:
for(EClassifier eClassifier : eClass.getEPackage().getEClassifiers())
if (eClassifier instanceof EClass)
> EClasses.
That's not possible unless you put a custom Adapter on the EPackage at the time you register it:
ePackage.eAdapters().add(new MyPackageAdapter(registry));
registry.put(ePackage.getNSURI(), ePackage);
Note that an EPackage can be registered with multiple registries, so you'll have to iterate over the adapters later.
Cheers
/Eike
http://www.esc-net.de
> Thanks a lot,
> Tassilo
Re: Getting from an EPackage to the EPackage.Registry it was registered with [message #1233667 is a reply to message #1233265] Mon, 20 January 2014 08:31 Go to previous message
Member
Thanks, Eike!
Previous Topic:Persisting object as XMI using Ecore model
Next Topic:create Proxy objects
Current Time: Tue Sep 22 14:43:44 GMT 2020
Powered by FUDForum. Page generated in 0.02394 seconds
