Home » Eclipse Projects » GEF » DropTargetListener version
DropTargetListener version [message #200770] Thu, 27 October 2005 05:41 Go to next message
Originally posted by: wjancz.\/\/asko.pl(change \/\/ with w)
Hi. This question is especially for Randy and Pratik.
I am using GEF 3.1.
I am adding into my GraphicalViewer class a listener which accepts dropping
elements.
I extends an AbstractTransferDropTargetListener class which implements
deprecated interface TransferDropTargetListener.
I hvae noticed that Eclipse warn me about using deprecated method.
Why AbstractTransferDropTargetListener uses deprecated interface when the
deprecate reason tells:
"@deprecated use org.eclipse.jface.util.TransferDropTargetListener instead".
So why You decided not to use org.eclipse.jface.util... instead ?
Or maybe higher version of GEF fixes this ?
Anyway... :) Thank for GEF! :)
...::WojT::..
Re: DropTargetListener version [message #200806 is a reply to message #200770] Thu, 27 October 2005 11:47 Go to previous message
Originally posted by: none.unknown.com
"WojT" <wjancz@\/\/asko.pl(change \/\/ with w)> wrote in message
news:djq7bj$7kf$1@news.eclipse.org...
> I am using GEF 3.1.
dropping
> elements.
instead".
For backward compatibility. ATDTL was implementing GEF's
TransferDropTargetListener before it was deprecated, and we can't just
change that now since it would break API for clients casting it to that
class.
> ..::WojT::..
Previous Topic:problem with Properties
Next Topic:[ANN] Performance Results now available
Current Time: Thu Jun 12 08:22:40 EDT 2025
Powered by FUDForum. Page generated in 0.08400 seconds
