Home » Eclipse Projects » GEF » Add new resource to navigator
Add new resource to navigator [message #199981] Thu, 20 October 2005 06:02 Go to next message
Originally posted by: prashanto.chatterjee.softwareag.com
Hi All,
The kind of feature that I am looking for is this - I am inside an
EditPart's performRequest() method. From here I would like to create a new
Resource in the navigator view. Somwhow I cannot find any handle to create
a new resource. My current code looks like this:
public void performRequest(Request req) {
if(req.getType().equals(REQ_OPEN)){
setSelected(SELECTED_NONE);
try{
IWorkbenchPage page =
((DefaultEditDomain)getViewer().getEditDomain()).getEditorPa rt().getSite().getPage();
IFile newFile =
EditorUtils.createNewFile(((Shape)this.getModel()).hashCode( )+ ".eci");
IViewPart navView =
(ResourceNavigator)page.findView(IPageLayout.ID_RES_NAV);
deactivate();
AppEditor editorPart =
(AppEditor)IDE.openEditor(page,newFile,"appedit",true);
editorPart.addPageSequence((PageSequence)getModel());
}catch(Exception we){
we.printStackTrace();
I have got the handle to the navigator but cannot find a way to add a new
resource to the navigator. Please help.
Appreciate any help in this regard,
Prashanto Chatterjee
Re: Add new resource to navigator [message #200078 is a reply to message #199981] Thu, 20 October 2005 12:34 Go to previous messageGo to next message
Originally posted by: none.unknown.com
You don't create the resource "in the navigator view." The navigator view
shows whatever resources are in the workspace, and you just create a
resource in the workspace.
Here's an example from one of our tests that might prove helpful to you:
// Create the logic file if it doesn't exist
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
IProject project = root.getProject(prjName);
if (!project.exists())
project.create(null);
if (!project.isOpen())
project.open(null);
file = project.getFile(fileName);
if (!file.exists()) {
LogicDiagram diagram = createLogicDiagram();
ByteArrayOutputStream out = new ByteArrayOutputStream();
ObjectOutputStream oos = new ObjectOutputStream(out);
oos.writeObject(diagram);
oos.close();
file.create(new ByteArrayInputStream(out.toByteArray()), false, null);
out.close();
If you're still having problems, I suggest you post on the platform
newsgroup with more details (about what happens when you execute your code
and such), since this is not GEF's domain.
"Prashanto" <prashanto.chatterjee@softwareag.com> wrote in message
news:37e7165eda181c20c08a40b9007fcdb6$1@www.eclipse.org...
> Hi All,
> try{
etPage();
> IFile newFile =
> IViewPart navView =
> deactivate();
Re: Add new resource to navigator [message #200352 is a reply to message #200078] Fri, 21 October 2005 15:37 Go to previous messageGo to next message
Originally posted by: pbeagan.yahoo_dontspamme_.com
Any resource creation/modification should be done using the
WorkspaceModificationOperation class to avoid getting out of sync with the
file system.
> project.open(null);
> oos.close();
> out.close();
>> Hi All,
>> new Resource in the navigator view. Somwhow I cannot find any handle to
>> create a new resource. My current code looks like this:
>> try{
> etPage();
>> IFile newFile =
>> IViewPart navView =
>> deactivate();
Re: Add new resource to navigator [message #200465 is a reply to message #200352] Mon, 24 October 2005 10:58 Go to previous message
This utility class seems to only provide batched notification of changes to
resource change listeners. How does it relate to things being in sync??
"Patrick" <pbeagan@yahoo_dontspamme_.com> wrote in message
news:djbfgv$19t$1@news.eclipse.org...
> file system.
Previous Topic:create a connection between a node and a connection
Next Topic:antialiasing affecting thumbnail
Current Time: Sat May 17 15:47:26 EDT 2025
Powered by FUDForum. Page generated in 0.03826 seconds
