CTRL+<key> combination possible? [message #199939] |
Wed, 19 October 2005 20:15  |
looking at and copying from Logic example and
LogicEditor.getCommonKeyHandler() , i started to implement
key combinations for certain actions.
But i get stuck, when i try to implement key combinations with modifiers
like ALT or CTRL !
Whereas this does work fine in LogicEditor.getCommonKeyHandler() :
sharedKeyHandler.put(KeyStroke.getPressed('j', 106, 0),
getActionRegistry().getAction(MyAction.ID)); // single j as key
something like this does NOT work:
sharedKeyHandler.put(KeyStroke.getPressed('j', SWT.CONROL),
getActionRegistry().getAction(MyAction.ID)); // single CTRG+j as key
Where is the problem? I know, that there are some exceptions for key
combinations like CONROL+X, CONROL+V, but i tried it with many different
characters and none of it worked.
Thanks in advance
Sven Wende
Re: CTRL+<key> combination possible? [message #200036 is a reply to message #199939] |
Thu, 20 October 2005 09:41  |
I think CTRL+J produces some other character that is not J.
There is an SWT snippet that prints out every key event you type. You can
quickly find out what event is generated for any key combination.
BTW, there are many scenarios where the keyhandler is not appropriate
because it will not work unless the viewer has focus. Also, it is not easily
customized by the user and the user will not be informed of conflicts that
he/she creates when customizing other keystroked in the IDE.
You should use commands when appropriate.
"Sven Wende" <s.wende@brain-time.de> wrote in message
news:dj6nij$skf$1@news.eclipse.org...
> like ALT or CTRL !
> Thanks in advance
> Sven Wende
FUDForum. Page generated in 0.04340 seconds
