Export error [message #198285] |
Wed, 07 March 2007 18:00 |
Originally posted by: vinays84.hotmail.com
Often when I try to export a war file in Eclipse WPT, I'll get an eclipse
export error which seems to be rooted to some NullPointerException
somewhere in the export process. The copied stack trace is below.If anyone
can shed some light, it would be appreciated. Thanks!
org.eclipse.core.runtime.CoreException: Extended Operation failure:
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentExportOperation
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard.performFinish(DataModelWizard.java:182)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:355)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:660)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.ui.actions.ExportResourcesAction.run(ExportResou rcesAction.java:180)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:168)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
org.eclipse.core.runtime.CoreException[0]:
org.eclipse.core.commands.ExecutionException: Error exportingWar File
org.eclipse.jst.j2ee.internal.archive.operations.J2EEArtifac tExportOperation.execute(J2EEArtifactExportOperation.java:78 )
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl$1.run(DataModelPausibleOperationImpl .java:376)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.runOperation(DataModelPausibleOperat ionImpl.java:401)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.runOperation(DataModelPausibleOperat ionImpl.java:352)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.doExecute(DataModelPausibleOperation Impl.java:242)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.executeImpl(DataModelPausibleOperati onImpl.java:214)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.cacheThreadAndContinue(DataModelPaus ibleOperationImpl.java:89)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.execute(DataModelPausibleOperationIm pl.java:202)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard$1$CatchThrowableRunnableWithProgress.run(DataMod elWizard.java:211)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Caused by:
org.eclipse.jst.j2ee.commonarchivecore.internal.exception.Sa veFailureException:
Error opening archive for export..
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentExportOperation.export(WebComponentExportOperation.java :44)
org.eclipse.jst.j2ee.internal.archive.operations.J2EEArtifac tExportOperation.execute(J2EEArtifactExportOperation.java:71 )
... 10 more
Caused by: java.lang.NullPointerException
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.Loa dStrategyImpl.getLoadedMofResources(LoadStrategyImpl.java:33 6)
org.eclipse.jst.j2ee.internal.archive.operations.ComponentLo adStrategyImpl.getLoadedMofResources(ComponentLoadStrategyIm pl.java:441)
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.Archive Impl.getLoadedMofResources(ArchiveImpl.java:687)
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.Sav eStrategyImpl.saveMofResources(SaveStrategyImpl.java:186)
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.Sav eStrategyImpl.save(SaveStrategyImpl.java:99)
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.Archive Impl.save(ArchiveImpl.java:1083)
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.ModuleF ileImpl.save(ModuleFileImpl.java:161)
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.Archive Impl.saveAsNoReopen(ArchiveImpl.java:1178)
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentExportOperation.export(WebComponentExportOperation.java :40)
... 11 more
Re: Export error [message #198317 is a reply to message #198285] |
Wed, 07 March 2007 18:35 |
Originally posted by: eclipse5.rizzoweb.com
> eclipse export error which seems to be rooted to some
> NullPointerException somewhere in the export process. The copied stack
> trace is below.If anyone can shed some light, it would be appreciated.
Are you talking about WTP? If so, then you should post your question to
the eclipse.webtools newsgroup to get more response.
Hope this helps,
Eric
FUDForum. Page generated in 0.07709 seconds
