Self-signing tool [message #1219964] |
Sat, 07 December 2013 08:34  |
Once I had JDK installed but since I use Eclipse at one point I decided
I did not need it and uninstalled it.
Now, however, the applet in my sig below is now giving a warning that
says that
"Running unsigned applications like this will be blocked in a future
release because it is potentially unsafe and a security risk."
So I've decided to self-sign my applet. To do so, from what I've found
out so far, I have to use a JDK tool.
Is there by chance a self-signing tool in Eclipse that I do not know about?
Also if I have to install JDK, and since JDK contains JRE, should I
unistall JRE? (This question of course is not related to Eclipse, but
it's related to the former one.)
emf
Natal Transits Calculator
https://files.nyu.edu/emf202/public/jv/nataltransits.html
Re: Self-signing tool [message #1219969 is a reply to message #1219964] |
Sat, 07 December 2013 11:16  |
> says that
I would not. My practice is to install a separate JDK that doesn't
disturb whatever JRE I'm running on my host so that updates to my host
base software do not affect my development in Eclipse. And I'm in
complete control of what Eclipse is using. So, I download and explode a
JDK on a path like /home/russ/dev/jdk1.7.0_25 and wire Eclipse up to it
using eclipse.ini (but, that's not important) and especially in Window
-> Preferences -> Java -> Installed JREs.
> emf
Best of luck.
FUDForum. Page generated in 0.13872 seconds
